Hello!!!
Edit: I found your problem. Disregard above errrr below now. Your url Is actually:
GET /
www.philsweather.co.uk" (from "viewtopic.php?f=52&t=1405&p=6705
instead of just
www.philsweather.co.uk When I manually typed it out of curiosity it worked perfectly.
Going back to your post and hovering over your link the above /forum/viewtopic……………. came up in my windows developers edition. I believe you can also turn yours on in settings somewhere.
Just a guess but it's in your index.html redirect or you copy and pasted it somewhere by accident.
Hello!
As Johnny said above. your first link does not connect... yet corrected to
http://www.philsweather.co.uk/ and site looks fine with everything seeming to work as should but only a quick glance. A few issues may be causing your issue.
1) ICANN hasn't received your verified dns from your host yet. Takes up to 48 hours after setting up new site, moving it to a different host with different dns or just changed your site name of course hence the (http://)
2) You changed your dns or reset it on your host depending if your host server allows that access.
3) you re-wrote your index.html with an incorrect url or redirect.
example of your index.html file should contain:
<meta http-equiv="refresh" content="0; url=
http://www.philsweather.co.uk/meteotemp ... esktop.php" />
There is a full example in the wiki somewhere and you only need to edit your path.
4) Or mis configured your .htaccess file also in root ./ if in fact you set it up and edited it.
google .htaccess setup or example .htaccess.
After you correct whichever problem it might be then just your (
www.philsweather.co.uk) will work alone.
Just my thoughts... feel free to correct me if I'm wrong.
