Meteohub - UV data *SOLVED*
Posted: Tue Jun 26, 2018 10:40 pm
Is it possible to get UV data through the Meteohub plugin into the template?
I can see UV data in the clientraw.txt file that I got from Meteohub. Line 79.
In Extra Tabel Setup I can set "Save in Database" for UV
I can add extra sensor for UV, I see the extra data table in my MySQL.
What do I miss for settings to collect UV data from clientraw.txt file? (If it's possible)
2018-06-29
Have found in apiLog.txt following row:
Sensor: UV not found in API file, skipping..., suppose it should be a zero value even if it's late evening here now, not much UV radiation.
So take it from there
, continue digging
BR
Christian
2018-06-29
BR
Christian
