WEBCAM plugin & CRONJOB
Posted: Wed Jul 11, 2018 10:27 am
Hi Everyone !
I am unable to make the plugin work properly, there is something I don't understand, or that I am doing wrong. So I need your help !!!!
1. Upload the files in my plugin directory --> done
2. Set up the plugin in my control panel --> done
3. Move the updateWebcam.php file into the load/crons folder --> done
4. Launch the Cronjob at the address /template/load/cron.php?password=***** --> done
I think it executes correctly, because I have an answer on the webpage. A image is saved, a thumbnail is created, as well as the table and everything.
But.... that's all ! No additional image is saved. Looks like the cronjob is running only manually and not on a regular basis. Images are saved only when I connect to /template/load/cron.php?password=*****
So I think something is missing, or wrong. I have tried to change the plugin settings, or to have a look in the file, but I don't have the knowledge.
Would be happy to have some assistance !
Thank you !!
Thank you !!
