WXSim CSV file not found
Posted: Wed Aug 08, 2018 8:31 pm
by LillianWX
I am having a bit of a problem displaying the wxsim forecast using the wxSim Forecast Plugin. A message is displayed "WXSim CSV file not found". You can view it here at: http://www.lillianweather.com in the center column at the bottom. Select WXSim where Weather Underground is shown.
The plugin instructions contain notes on how to edit certain parameters the forecast.php file. There is also a wxsim plugin setup in the meteotemplate setup which contain essentially the same parameters found in the forecast.php. I presume if one edits the parameters in the plugin setup then it is not necessary to manually edit the forecast.php file. If not someone please tell me.
I found a 3 yr old post in one of the weather forums from someone who had the same issue with the csv file not found. It was explained that it was best to use a relative path for the latest.csv path parameter. This is probably/maybe MY problem. I have tried many different paths without success, i.e. ../../latest.csv (default), ../../../latest.csv, etc.. I've used 0-4 levels up. I'm no expert on relative paths as I rarely use them. Could someone help me out on what I should put there for the relative path? What I have used is not working. I have the latest.csv file in public.html/template folder. I am using version 17.0 and all of the blocks/plugins are the latest ones.
Thanks,
Re: WXSim CSV file not found
Posted: Thu Aug 09, 2018 8:47 am
by Asobig
Only Blocks show up on the page, Plugins are in the topmenu. Your topmenu has only Home.
The path to the files on my site is: '../../uploadwd/latest.csv'
I think that in your case it should be something like
'../../template/latest.csv'
Posted: Thu Aug 09, 2018 7:04 pm
by LillianWX
Asobig,
Thank you for setting me straight on this. In my Block/Plugin confusion I had not noticed that I had lost my menu somehow during the update process. This opens up another can of worms for me.
LillianWX
www.Lillianweather.com
