warningsau
Posted: Thu Sep 13, 2018 12:21 pm
by tpweather
Hi All
Anyone else who is warningsau having errors?
Mine is giving an error which can be viewed here:
www.tpweather.com.au
Many thanks in advance.
Chris
Re: warningsau
Posted: Fri Sep 14, 2018 3:23 am
by John B
Yes, Chris..
The Australian conditions block, too.
Both return the 'Data unavailable' message.
AS it happens they are both in the same menu block. I don't think that's the problem as another block is not affected.
I suspect that it's either a BoM problem or it has altered some of its data formats.
P.S. - The link you posted does not work.
Re: warningsau
Posted: Sat Sep 15, 2018 1:56 am
by tpweather
Thanks John. I have fixed the link.
Re: warningsau
Posted: Sat Sep 15, 2018 11:47 pm
by stuee
Hi.
Im having this same issue on both the blocks, how did you fix it?
Re: warningsau
Posted: Sun Sep 16, 2018 7:02 am
by John B
No, stuee, Chris merely mentioned that the incorrect link to his site had been adjusted.
Re: warningsau
Posted: Mon Oct 08, 2018 2:33 am
by tpweather
Hi All
Anyone figure this out yet? I've tried playing around with it no luck.
Cheers
Chris
Re: warningsau
Posted: Tue Oct 23, 2018 2:54 am
by Aussie Susan
I had a very similar problem with one of the skins for weewx - it turns out that the BoM requires a "User-Agent" entry in the HTTP header that retrieves the data.
NOTE: USE THE FOLLOWING AT YOUR OWN RISK
I edited the 'currentAustraliaBlockLoader.php' file at around line 64 to change:
to be:
$opts = [
"http" => [
"method" => "GET",
"header" => "User-Agent: Mozilla/5.0 (Windows NT 6.1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/41.0.2228.0 Safari/537.36"
$context = stream_context_create($opts);
$html = file_get_contents($url, false, $context);
I have no idea if you need all that text in the 'User-Agent' line but I copied that from somewhere a while ago and it works. Experiment if you like.
I suggest that you backup the file before editing it.
Also the location of the file probably depends on where you installed Meteotemplate but for me it was in the subdirectory meteotemplate/homepage/blocks/currentAustralia.
Susan
Re: warningsau
Posted: Sat Nov 03, 2018 12:06 pm
by tpweather
Thanks Susan, but where do I find currentAustraliaBlockLoader.php? It's not in the warningsAU block folder
Re: warningsau
Posted: Thu Nov 29, 2018 9:33 pm
by Aussie Susan
@tpweather - sorry but I've only just seen your message.
I gave the location where the file was on my system. I suggest that you grep for 'file_get_contents' and see which one(s) are in an appropriate place and probably look something like '"$html = file_get_contents($url)".
By the way, I see in my post above I incorrectly typed the code I altered: it was not 'file_get_context' but 'file_get_contents'. The replacement code is correct though.
Susan
Re: warningsau
Posted: Fri Nov 30, 2018 1:52 pm
by tpweather
Yup thanks Susan. I realise that now. sorry, I am talking about the warningsAU block. I do not use the Australia
Current Conditions block, hence my confusion! I'm really keen to get the warningsAU block up and running if you have any suggestions??
Re: warningsau
Posted: Sun Dec 02, 2018 5:41 pm
It looks like several AU blocks stopped functioning due to changes in data source
Re: warningsau
Posted: Sun Dec 09, 2018 8:45 am
Update available for both current conditions and warnings
Re: warningsau
Posted: Sun Dec 09, 2018 10:27 pm
by John B
Thanks, Jáchym, your time and trouble are very much appreciated.
Re: warningsau
Posted: Mon Dec 31, 2018 7:29 am
by tpweather
many thanks Jachym. Happy New Year
