End of Service for the Weather Underground API
Posted: Sat Oct 06, 2018 6:39 pm
by Johnny
Re: End of Service for the Weather Underground API
Posted: Fri Oct 12, 2018 3:01 pm
by Fraggboy
Interesting read.
This really has me interested.. "If you are a Personal Weather Station owner, you will receive more information about our plan to offer free access to the data you provide to Weather Underground. We’ll reach out once that plan has been finalized."
Posted: Fri Oct 12, 2018 3:38 pm
by Johnny
Let's wait and see what happens :)
Posted: Fri Oct 12, 2018 3:58 pm
by Fraggboy
I actually re-signed up to WU, so yes. I agree. We will see..
Posted: Fri Jan 04, 2019 5:59 pm
by nicoloconte
"All Weather Underground API keys will stop working on February 15, 2019 unless otherwise agreed upon with Weather Underground."
https://apicommunity.wunderground.com/w ... api-update
Posted: Thu Jan 10, 2019 9:32 am
by nicoloconte
Just an info, actual weather station that send data to WU, will continue to work? Or I have to change weather station?
Posted: Sat Jan 26, 2019 5:17 pm
by nicoloconte
Posted: Sat May 25, 2019 10:05 pm
by tinso
After my website been mostly down since the old WU API is been taking away (I own an AcuRite 5 in 1 which it only communicates with WU). I check on WU and I did got a new API key and thanks to user nicoloconte I was able to create an small php file to use that new API with the Meteotemplate API. Currently is working, I just finished a few hours ago so don't know the reliability of the new WU API. I uploaded this new php to the update folder and modified the cronjob to execute this one instead of the update.php. See attachment, don't judge this is my first php. Also make sure this php has execution permissions.
Posted: Sun May 26, 2019 2:15 pm
by kevin
Hi Tinso just modify in my template have Froggit Hp 1000 SE and have same problem only work WU :( just make new file PHP and it s work now :) so have others parameter if you help me have Solar radiations and UV what add in the Php file ?
Find and have solution , share to other users :)
added in the php file :
$voSolarRadiation = ($obj['observations'][0]['solarRadiation']);
$voUv = ($obj['observations'][0]['uv']);
$mtURL = "http://your site.com/api.php?U=".$voTimeStm."&T=".$voTemp."&H=".$voHum."&P=".$voPress."&W=".$voWindSpeed."&G=".$voWindGust."&B=".$voWinDir."&R=".$voRainTotal."&RR=".$voRainRate."&S=".$voSolarRadiation."&UV=".$voUv."&PASS=yourpassword";
Uv not working older api , and now is ok :) solar radiation and uv now see on current conditions.
Very Thx for Job Tinso and nicoloconte.
Thx you
Posted: Tue May 28, 2019 12:04 am
by RobF
OK, beautiful I get the json data when using the https://api.weather.com/v2/pws/observat ... stationId=... URL, but the cron does not update the data and if I go into the Meteotemplate admin and try to set it up as a custom api with the new api script, and try the "Show Field Numbers" this is what I get:
Loading file...
Loading CSV/text file from NewWUAPI.php
File loaded successfully.
Starting to parse data....
Loaded data:
Field Number Value
0
So it appears I am missing a step.
Troubleshooting now, but any tips? Most likely I am missing something important...
Posted: Fri May 31, 2019 1:07 am
by tinso
Kevin, I'm glad you got it working again, you're welcome. It's been very reliable so far only once I got a notification that the new WU API failed, but it was around 3am so I'm not complaining.
kevin wrote: Sun May 26, 2019 2:15 pm Hi Tinso just modify in my template have Froggit Hp 1000 SE and have same problem only work WU :( just make new file PHP and it s work now :) so have others parameter if you help me have Solar radiations and UV what add in the Php file ?
Thx you
Posted: Fri May 31, 2019 1:15 am
by tinso
RobF I think you're trying to use Custom File instead of the API option from the drop down. I don't export the json data to a csv, I extract the data that my WS provides and using the Meteotemplate API use it to update the webpage every 5 minutes. See here for information on how to use the API.
RobF wrote: Tue May 28, 2019 12:04 am OK, beautiful I get the json data when using the https://api.weather.com/v2/pws/observat ... stationId=... URL, but the cron does not update the data and if I go into the Meteotemplate admin and try to set it up as a custom api with the new api script, and try the "Show Field Numbers" this is what I get:
Loading file...
Loaded data:
Field Number Value
0
Posted: Sat Jun 01, 2019 12:20 am
by MacV
Thanks Tinso and Kevin for sharing this solution, was getting tired of seeing station offline!
Marc
www.pare361.co.nz
