PB WITH METEOHUB
Posted: Thu Oct 18, 2018 3:23 pm
by PNCATTE
I transmit the data of my meteohub with the meteohub script but the solar data do not correspond to that of the file clientraw.txt
221 W displays 53 W
Thank you in advance for your help
Same file on two site to see the difference
http://www.fleurie-meteolive.ovh/template/index.php
bad value
http://www.fleurie-meteolive.ovh/index.php
Good value
cordially
Re: PB WITH METEOHUB
Posted: Wed Oct 31, 2018 9:11 pm
by Mauro
Hello Pncatte!
Same problem with my setup.
The solar radiation data are significantly lower than those shown in the file clientraw.txt
I use Meteohub version 5.0z in a VM.
I temporarily solved by taking data from WU.
I hope a solution is found soon.
Best regards!
Mauro
Posted: Tue Nov 06, 2018 9:59 am
by Mauro
