graphCombined block
Posted: Sun Dec 02, 2018 10:06 am
by meteoesine
Hi there,
I'm looking for who has modified this block with colored lines.
I saw his template some days/weeks ago but now I do not remeber he was and I can't find it anymore.
If you are reading, pls kindly share your interesting modification.
Re: graphCombined block
Posted: Mon Jan 28, 2019 2:38 pm
by WSKO_Karlchen
How can i add TS1 to TS4 and SM1 to SM4 to the graphcombined Block?
Tried it by myself - but failed...
A hint from anybody - or maybe a running script?
Tried to add this in data.php
if(in_array("TS1", $graphsToInclude)){
            if($row['TS1'] === "" || $row['TS1'] === null){
                $rawData['TS1'][] = null;
            else{
                $rawData['TS1'][] = convertT($row['TS1']);
and add this
if($parameter == "TS1"){
            $data['datasets'][] = array("name" => lang('soil temperature 1','c'), "data" => $rawData['TS1'], "unit" => unitFormatter($displayTempUnits), "type" => "line", "valueDecimals" => 1);
but it wont work :(
Posted: Wed Jan 30, 2019 5:31 pm
by lemimi
If colored lines in graphCombinedblock still interest you, I just did this:
https://www.lemimi.fr/template/indexDesktop.php
In the graphCombinedBlock.php file,
line 286, I replaced:
color: '# <? php echo $ graphColor?>',
by
lineColor: dataset.lineColor,
In the data.php file,
I added:
, "lineColor" => "#dddddd"
to lines 133,136,139,142,145,148,151,154 and 157
Like this:
$ data ['datasets'] [] = array ("name" => lang ('temperature', 'c'), "data" => $ rawData ['T'], "unit" => unitFormatter ($ displayTempUnits ), "type" => "line", "valueDecimals" => 1, "lineColor" => "#dddddd");
And just change the value of #dddddd to change the color of the line.
The transformed files are downloadable here:
www.lemimi.fr/download/data.zip
www.lemimi.fr/download/graphCombinedBlock.zip
Michel
Posted: Thu Jan 31, 2019 7:32 am
by meteoesine
good job. well done!
tnx
Posted: Thu Jan 31, 2019 8:53 am
by Jolumarali
Merci Michel, parfait
Posted: Thu Jan 31, 2019 6:10 pm
by lemimi
Bonsoir José Luis,
Comme beaucoup de français, je ne maitrise pas parfaitement l'anglais et le traducteur de Google m'aide beaucoup.
Aussi lorsque j'ai installé Meteotemplate, je me suis amusé à traduire le setup et le menu en français pour pouvoir m'y retrouver plus facilement.
Et aussi et surtout à sauvegarder au fur et à mesure!
- pour /template/install/setup.php en français:
http://www.lemimi.fr/download/mtotemplate/setup.zip
- pour /template/admin/menu/menuTabs.php en français:
https://www.lemimi.fr/download/mtotemplate/menuTabs.zip
J'ai aussi modifier le fichier /template/lang/fr.php
https://www.lemimi.fr/download/mtotemplate/fr.zip
J'ai mis ' à la place de \\'
72 modifications et cela corrige les problèmes d'affichage de l'apostrophe dans les différents menus.
On a ainsi par exemple:
Qualité de l'air au lieu de Qualité de l\'air
Si cela peut aider certains que l'anglais rebute...
Bonne soirée et au plaisir... Michel
Posted: Sun Feb 03, 2019 6:15 pm
by Jolumarali
Merci Michel
Idem pour l'anglais , merci Google
Très bon travail.
Mise à jour effectué , en gardant bien les Zip , car si Jachym mets à jour Meteotemplate le setup et menuTbas vont être écrasé,
pour le traducteur, il mettra ta traduction lang. à jour,
et encore bravo
amitiès
Posted: Tue Feb 05, 2019 10:56 am
by andyk1
lemimi wrote: Wed Jan 30, 2019 5:31 pm Hello,
Michel
Hello and thank you!
More than likely what I was looking for also. I have a light color (gray) background and that block came up blended into a light color also and barely readable.
Thanks for your effort.
Posted: Tue Feb 05, 2019 1:36 pm
by andyk1
Michel
I tried you're modified blocks but as you can see at www.nicomaparkwx.com at the bottom center the background color is a light color and I need to change the graph and text to a darker shade. Not sure why my MT is doing that as all the other blocks work just right.
Anyway I need to get in there and find the text color and the graph lines and change this block to black.
Thanks again. You put me on the right track.
Posted: Tue Feb 05, 2019 2:59 pm
by lemimi
I just put my theme in "LIGHT" like you.
On "/template/admin/createHomepage.php?type=desktop",
I added in the box "Highlighted blocks:" graphCombined
See what this gives right now on:
It's a little better. . .
Michel
Posted: Tue Feb 05, 2019 3:58 pm
by andyk1
I did as you suggested. I left it light the first time and added graphCombined to the highlighted Block but still could not see the graph. Dark of course worked but I do not prefer the dark theme. Silver is what I am looking for. I only need to change the graph text color and outlines. I know the color is in the Main setup php to control the color through out the blocks. I just haven't had time to dig through it to see how there controlled and why this one block refuses to cooperate... :roll:
Thanks anyway. I'll leave your suggestion up till you have a chance to look at it before I go digging through the main PHP files.
Posted: Tue Feb 05, 2019 5:43 pm
by lemimi
Look here (bottom of page):
https://www.nicomaparkwx.com/wx/indexDesktop.php
I do not know how he did to change the fund but
it seems to me that it is close to what you are looking for.
Michel
Posted: Tue Feb 05, 2019 7:12 pm
by andyk1
lemimi wrote: Tue Feb 05, 2019 5:43 pm Look here (bottom of page):
Michel
Hello Michel!!!
Yes you are correct but only in a dark theme. When I change it back to light as I've always had it is hard to read. Actually now it is a light blue but I think that is the setting you changed. The graphs are still hard to read is what I need to fix.
Posted: Tue Feb 05, 2019 9:03 pm
by WSKO_Karlchen
Is there no solution to add other sensors to this block? Like I mentioned to add soil moisture and temp data?
Posted: Wed Feb 06, 2019 5:37 am
by andyk1
Good point. maybe a suggestion for the version 18. I don't have one but am sure a script could be written in by someone that has those sensor.
