display external php guestbook on the same page
Posted: Fri Dec 07, 2018 4:40 pm
by LeShark1205
Hello community, I have deleted my previous post because they have solved almost by themselves and some try themselves.
Now have another common problem and I hope that I can be helped, I downloaded the
https://www.php-guestbook.de/ and installed, as far as it works, only if I have a link to the menu Insert the guestbook opens in a new window, my question: "Is there a way and how it opens in the same window as the template?
Hope I expressed myself understandable! Gladly available for counter questions;)
greeting
Harry
Re: display external php guestbook on the same page
Posted: Sat Dec 08, 2018 5:20 pm
by blaineca
I'm not really sure what you mean by "same window", but there is a guestbook plugin for MT
Posted: Sun Dec 09, 2018 11:42 am
by LeShark1205
blaineca wrote: ↑Sat Dec 08, 2018 5:20 pm
Since I personally do not like the plugin, I would like to include another guestbook, I've added a photo montage that illustrates what I want to illustrate
- montage.png (405.52 KiB) Viewed 21078 times
Posted: Mon Dec 10, 2018 1:11 am
by blaineca
You can make a custom page to show it.
Refer to the meteotemplate wiki under "Customization". This section might help you get started
Posted: Tue Dec 11, 2018 8:55 am
by LeShark1205
blaineca wrote: ↑Mon Dec 10, 2018 1:11 am
Does not work, unfortunately, my guestbook is always opened in a new window and not in the template under the menu
http://wetter-hiltenfingen.euro-picture.de see menu "test", "guestbook"!
Best regards
Posted: Tue Dec 11, 2018 10:40 pm
by BlueBear
Posted: Wed Dec 12, 2018 8:27 am
by LeShark1205
Thank you BlueBear, as far as it goes, only in the menu your menu is displayed and not mine, I forgot something because or you have to add something in the "gbook.php"?
And how do I integrate it into the menu?
Thank you in advance
greeting
Harry
http://wetter-hiltenfingen.euro-picture ... /gbook.php
Posted: Wed Dec 12, 2018 12:36 pm
by LeShark1205
Posted: Wed Dec 12, 2018 1:57 pm
by BlueBear
Looks like you figured it out!
Posted: Wed Dec 12, 2018 2:02 pm
by LeShark1205
BlueBear wrote: ↑Wed Dec 12, 2018 1:57 pm
Thanks again, but I can not figure out how to integrate it into my standard menu
Posted: Wed Dec 12, 2018 2:51 pm
by BlueBear
Go to your Admin area and look for Menu Setup
Then in the area where you want it to appear add something like this:
Test Guestbook|
http://www.sanfordweather.com/meteo/cus ... ook.php|fa fa-book
LeShark1205 wrote: ↑Wed Dec 12, 2018 2:02 pm
Posted: Wed Dec 12, 2018 4:26 pm
by LeShark1205
BlueBear wrote: ↑Wed Dec 12, 2018 2:51 pm
Test Guestbook|
Thank you !!!!
It works...
Now only has to adapt the file ...
Thank you very much
greeting
Harry
Posted: Fri Dec 14, 2018 12:11 pm
by LeShark1205
Please do not misunderstand, but can not you take the header and footer with "include" from the actual template? Then you would save the complete rewrite!
Harry
Posted: Fri Dec 14, 2018 2:00 pm
by BlueBear
I don't think so but then I'm not a programer, just a hacker!
LeShark1205 wrote: ↑Fri Dec 14, 2018 12:11 pm
Harry
Posted: Fri Dec 14, 2018 2:29 pm
by LeShark1205
I thought you could combine one or the other with the other, because it is a lot of work to fit the gbook menu to the eigendliche menu ...
have already seen that you have it on it, have me installed your countdown counter on my HP;)
