Some blocks think station is offline
Posted: Sun May 05, 2019 8:27 pm
So out of the blue the stationStatus, the stationData and the little banner in the upper left under the country flag that used to scroll current data have all stopped working. I use meteobridge to update the meteotemplate api and that is getting an ok, I ran the system checks they all check, the steel series gauges are functioning, however the 3 other blocks mentioned above have all of a sudden stopped, as if the main template thinks the station is offline. The scrolling current conditions doesn't show up anymore at all. I reset the homepage and re-entered in all the blocks, I went through a main setup script again and checked everything, and re-created it, all looks ok there. I deleted and re-uploaded the blocks, and re-created the settings files from scratch, still no joy.
Any help with what I can check to fix this would be greatly appreciated. The url is:
http://www.w1ape.com
Thanks in advance !
Joe
Thanks in advance !
Joe
