radarAURegional
Posted: Sat Jul 13, 2019 2:14 am
by John B
This block, sourced from the Australian Bureau of Meteorology, has been 'faulty' for a few weeks. It is a block which depends on the consolidation of 'layers' to produce the desired effect,
Looking through the template files it looks as though it should work, but it doesn't. Prior to this the block has worked faultlessly.
Should anyone have an idea as to a solution I would be most happy to hear your advice.
Re: radarAURegional
Posted: Mon Dec 23, 2019 5:06 am
by stillie
Hi John
Have you had any response as I have the same problem with http://www.nanangoweather.com/template/
Alan
Re: radarAURegional
Posted: Mon Dec 23, 2019 10:55 pm
by John B
G'day, Alan,
Unfortunately not, old man. I'm afraid that since Jáchym managed to snag a full time job with his local met. bureau maintenance of the template has dribbled away to virtually none. Until such time as someone on the site with more advanced knowledge of PHP than I can come up with a solution I've removed the block from my site.
Cheers,
Re: radarAURegional
Posted: Mon Dec 23, 2019 11:19 pm
by nineback
John B wrote: Mon Dec 23, 2019 10:55 pm G'day, Alan,
Cheers,
I've noticed the same. I wonder what the future holds for the template?
Re: radarAURegional
Posted: Mon Dec 23, 2019 11:56 pm
by John B
Alan,
I just looked at your site; your radarAURegional seems to be working properly. I cannot vouch for the actual radar images, but certainly the rest is! I've plonked it back on my main page - bottom right - but it still doesn't work for me. If you pop over to my site you'll see the result I get. Odd.
Re: radarAURegional
Posted: Tue Dec 24, 2019 12:17 am
by John B
Tom,
Who knows? I am not blaming Jáchym in the slightest. He used to work on the template for ridiculous hours when he was working part-time jobs. I would imagine that suddenly working full-time and, presumably, going through a steep learning curve, perhaps irregular hours, travel time and so on would leave very little time for what is essentially a hobby.
