API Problem?
Posted: Thu Sep 14, 2017 11:11 pm
by wxthomson
Suddenly my template isn't displaying current information
I don't remember changing anything
www.minnetonkaweather.com
WD seems to be sending the API or at least the WD Meteotemplate test is successful.
Re: API Problem?
Posted: Thu Sep 14, 2017 11:55 pm
by Luc
The actual data in file meteotemplateLive.txt seems up to date, but your database seems not providing data.
Check the error reports on your web server and also check in Meteotemplates Main Setup the MySQL 'Test Connection' button.
Re: API Problem?
Posted: Fri Sep 15, 2017 5:59 am
by Thomas
Same for me, current block not open or must wait several minutes to open.
All others blocks and database work.
EDIT : current block works when trends are disabled
Re: API Problem?
Posted: Fri Sep 15, 2017 7:55 am
by gillesroszak
HI
here also the current block is not working !!!!
Re: API Problem?
Posted: Fri Sep 15, 2017 10:15 am
I dont see any issues, works on my page and works on your as well, i just checked
Re: API Problem?
Posted: Fri Sep 15, 2017 10:18 am
by Thomas
Yes works now
Re: API Problem?
Posted: Fri Sep 15, 2017 10:23 am
Strange because it didnt work for a few seconds in the DEMO too, I refreshed the page twice and it works.... no clue why it would do this, it should either work or never work
Re: API Problem?
Posted: Fri Sep 15, 2017 2:21 pm
by dmgould
My pages have slowed way down several times the last few days. I think mine is caused by the database running slow. It is also intermittent. Last night it was so slow it would take the page 10-15 seconds to finally load. This morning it is coming right up normally.
Re: API Problem?
Posted: Fri Sep 15, 2017 4:35 pm
by wxthomson
gillesroszak wrote: ↑Fri Sep 15, 2017 7:55 am
HI
when I updated the current block the problem started now that I think about it.
Re: API Problem?
Posted: Fri Sep 15, 2017 6:06 pm
I dont think this could have anything to do, because the API is run before anything else, the current block just uses the current file already created by the API, but it is in no way involved in the API or db updates.
