New version 18.0
Posted: Wed May 06, 2020 1:34 pm
a new version is available (18.0 Papaya). Please see the blog for more info.
Re: New version 18.0
Posted: Wed May 06, 2020 9:19 pm
by nineback
I updated from 17.2 without any errors, however, the footnote at the bottom of the web page still shows Meteotemplate 17.2 Nectarine. I cleared my browser cache and it still shows 17.2. This happened on two different installations (different web addresses).
Posted: Thu May 07, 2020 12:41 am
by LOBWX
Sweet, thank you Jachym :D
Posted: Thu May 07, 2020 6:45 am
by MTQ
Updated and working smoothly. As always, updates are VERY easy.
Footnote at the bottom of the web page showing "18.0 Papaya".
Thank you Jachym!
Posted: Thu May 07, 2020 7:08 am
by MTQ
Hi again,
One issue I've seen is that the radarES block is not showing any radar info...
Posted: Thu May 07, 2020 10:13 am
by nineback
Jachym replied to an email I sent:
"after each update you need to go to the Main setup and click "save" even if you do not modify anything. This triggers update of the footer and several other scripts to finalize the update."
This guidance is at the very bottom of the update instructions on the blog (below the What Is New section). I only read the Update process section. :oops:
nineback wrote: Wed May 06, 2020 9:19 pm I updated from 17.2 without any errors, however, the footnote at the bottom of the web page still shows Meteotemplate 17.2 Nectarine. I cleared my browser cache and it still shows 17.2. This happened on two different installations (different web addresses).
Posted: Thu May 07, 2020 10:41 am
by Jure
Thank you Jachym!
Update went without a hitch! Papaya sure tastes good! :)
Jure
Posted: Fri May 08, 2020 1:57 am
by John B
Thanks, Jáchym.
The installation worked liked a well greased wheel.
Posted: Fri May 08, 2020 6:15 am
by Jolumarali
Bonjour Jachym
Après quelques problèmes pour obtenir le Key.
Mise à jour parfaite et très rapide.
Prends soin de toi
Posted: Fri May 08, 2020 7:15 pm
by Meteopomezia
Updated smoothly
everything works great
Thanks Jachym ;)
Posted: Sat May 09, 2020 12:04 pm
by F1SKF
I want to update from version 17.2 to 18.0.
Questions :
I copy the update folder of version 18.0 instead of the update folder of version 17.2?
To launch the update I launch the file: update.php? or updateSetup.php?
Thank you.
Herve
Bonjour,
je veux mettre à jour de la version 17.2 vers 18.0.
Questions :
Je copie le dossier update de la version 18.0 à la place du dossier update de la version 17.2 ?
Pour lancer la mise à jour je lance le fichier : update.php ? ou updateSetup.php ?
Merci.
Hervé
Posted: Sat May 09, 2020 12:53 pm
by nineback
Posted: Sat May 09, 2020 1:40 pm
by F1SKF
That's what i did, but:
2 - extract the package and inside you will find a folder update_18.0
I don't have a file update_18.0 !!
Posted: Sat May 09, 2020 2:58 pm
by Jolumarali
Bonjour
Tu installes update 18 (dézipper) dans le dossier update
et tu ouvres avec /update/update_18.0/updateTemplate.php
Une page va s'ouvrir et en bas du devrait voir succès
Avant tu ouvres panneau de configuration de meteotemplate et termine en sauvegardant (Save).
Bonne soirée
Posted: Sat May 09, 2020 10:47 pm
by F1SKF
BonjourJosé Luis,
J'avais bien compris tout çà :
" Tu installes update 18 (dézipper) dans le dossier update
Mais je n'ai pas de update 18 ni de updateTemplate.php dans le fichier meteotemplate_18.0.zip
Voila juste ce que j'ai dans le Zip de meteo template : un dossier update qui contient
Merci et bonne journée
Hervé
Posted: Sat May 09, 2020 11:00 pm
by F1SKF
Problème résolu !
En fait j'ai Meteotemplate V8 complet et non la mise à jour !
J'ai redemandé une clé à Jachym pour télécharger la mise à jour cette fois.
Hervé
meteo88.pecouba.fr
Problem solved !
In fact I have Meteotemplate V8 complete and not the update!
I asked Jachym for a key to download the update this time.
Herve
[url] meteo88.pecouba.fr
[/ url]
Posted: Sun May 10, 2020 7:59 am
by Jolumarali
En fait avec un peu de retard de lecture, c'est la réponse que je voulais te donner.
Bon déconfinement.
Posted: Sun May 10, 2020 8:50 am
by F1SKF
Mise à jour réussie.
Avec le bon fichier (update 18) c'est quand même mieux.
Merci pour l'aide.
Porte toi bien également.
Hervé
