Uploading WeatherCat data to Meteotemplate
Posted: Tue Aug 25, 2020 11:42 pm
1 am trying to find detailed instructions for uploading WeatherCat data to a Meteotemplate site I am setting up.
I am operating on WeatherCat Version 3.05 Build 27 (3.0.5)
I am told I do not now need to the generate a CRON job as WeatherCat will now directly generate an php.api directly for upload
In fact Meteotemplate has removed support for the plugin that used to be required
I have done the basic setup of the Meteotemplate and run a check and it says everything is correct except no php.api present.
Questions are.
1) Do I use the Custom Web option or the Custom CGI option (which seems to set up php.api
2) What are the detailed step by step instructions I need to follow i.e instructions for dummies
I’ve been trying for a number of weeks. I believe everything else in the Meteotemplate is set up correctly
I have been through the Meteotemplate a number of times but cannot find the specific instructions on data upload for WeatherCat
Questions are.
