Two webcams
Posted: Tue Sep 19, 2017 2:45 pm
by SwissWetter.ch
Hi into the community
A user from me needs to display 2 webcams.
How can I duplicate the webcamblock?
(this needs 2 Blockdefinitions?)
Thanks for answering
Markus
Re: Two webcams
Posted: Tue Sep 19, 2017 2:51 pm
by Johnny
Hi Markus
I don't think you need to duplicate the block (in fact you can't), read the instructions associated with the block and you will see that you can add more camera's just by adding each URL.
"It is possible to show more than one image. Simply enter the URL of all the webcam images you want to display. They will be displayed in the same order as given in the array. Next parameter then specifies the heading for each webcam. Make sure that they are in the order corresponding to the order of the URLs. The links and titles must be delimited with a comma ","
I'm sure other's will correct if I am wrong here.
Re: Two webcams
Posted: Fri Sep 22, 2017 8:54 am
by SwissWetter.ch
Hi Johnny
Thanks a lot for your message.
I'm on shame - I don't readed the Infos before the Inputfield.
It works now wonderful:
www.wetterfuchs.ch (right side)
Best regards
Markus
Re: Two webcams
Posted: Fri Sep 22, 2017 9:16 am
by Johnny
Hi Markus,
Nice to see both camera's all up and running. You can enter your map position if you want as the top camera image is still on the default of Brno and the bottom one is blank. You can use this link to find out your longitude and latitude.
https://www.findlatitudeandlongitude.com/
Stunning vistas by the way, I'm afraid I don't have anything that spectacular to look at as I live in the middle of a town - no mountains here.
