lightning block not showing map
Posted: Tue Nov 10, 2020 7:59 pm
by kratochh
Since some days the lightning block is not showing maps any more - is this a problem of my configuration or does anyone encouter the same issue?
Re: lightning block not showing map
Posted: Wed Nov 11, 2020 10:48 pm
by John B
No, kratochh, it is not your set up. It seems that Blitzortung has changed its file references/locations.
Posted: Sat Jan 23, 2021 2:14 pm
by kratochh
I just figured out what changes need to be done to work properly:
Just replace "images" with "www" in the link to the maps in the file "lightning_block.php"
https://www.blitzortung.org/Images/...... ;)
Posted: Mon Jan 25, 2021 10:14 pm
by John B
That is fantastic, kratochh, thank you ever so much. :D
For those who might have got confused trying to amend the lightningBlock.php file you can do the changes on the following lines:
106
147
154
160
166
172
178
184
190
196
203
On each of those lines you will find "http://images.blitzortung.org/Images ...". Simply change the word images to www thus:
http://www.blitzortung.org/Images...
Thanks again, kratochh, I am ever so pleased to have the block working again. 8-)
