Date problem using import module
Posted: Tue Nov 24, 2020 10:26 am
by marcelh
Hello to you all,
I try to import data from the past into the Meteotemplate database. I succieded in the past but now I get stuck on a date error. The import file contains data from 1951 until 2017 with one data entry for eacht day.
When starting the test it shows the correct date:
>> Parsing date and time...Date and time parameters all in separate fields.
>> MySQL accepts date and time in format YYYY-MM-DD HH:MM, the parsed date and time is: 1951-01-01 01:05
But at the end of the test I get this error message:
>> Parsing line 0 finished.
>> Checking validity of data based on your limits in Main settings...
>> Checking date and time...
>> There seems to be a problem with the date and time. Either it has not been parsed correctly or it is a date/time in the future! Check the format you specified and also the actual values.
I already tried a smaller import file, but with the same result.
Maybe someone has a clue what can cause this problem .....
Many thanks,
Marcel
Meteo Helmond
Re: Date problem using import module
Posted: Tue Nov 24, 2020 3:49 pm
by iatros
Hi marcelh
I don't know if that helps: In "Data Import" section is a notice concerning php and Date/Time formats:
Date/time: 2020-11-24 16:45
Format: Y-m-d H:i
Cheers, Martin
Posted: Thu Dec 03, 2020 10:19 am
by marcelh
Thanks for your reply Martin, but the format is correct according to the PHP settings (as shown in the most upper quote).
So this should be OK.
Marcel
Posted: Tue Dec 08, 2020 10:22 pm
by gand
Hi
I think you need to include seconds as well. So the format must be:
YYYY-MM-DD HH:MM:SS
That worked for me.
Gert
Posted: Wed Dec 09, 2020 10:42 am
by marcelh
Thanks Gand
With a previous import it worked OK in the way I mentioned above, so this should be OK (don't need seconds).
Marcel
Posted: Sat Jan 09, 2021 10:43 am
by marcelh
So since there seems to be no sollution data import isn't possible anymore .......
Good to know :|
Posted: Tue Jan 19, 2021 10:32 pm
Please attach the data you are trying to import ( or a part ), I can give a try
Posted: Sat Feb 06, 2021 10:22 am
by marcelh
Sorry for the late reply.
Please find attached the import file. Thanks a lot.
Posted: Sat Feb 06, 2021 12:22 pm
I have uploaded the document to google spreadsheet, lots of data present:
1) you should fill the first and second row ( only for the fields to import in the main table )
2) there are several '#WAARDE!' ( 125 ) across the spreadsheet, we should decide what to do with these cells, only for columns to be imported ( simple solution is to remove these warning or substitute with some data, a quick and dirty solution is remove these data and in a second time 'fill in the blanks' )
3) the table contains data from 1970 Jan 1 to 2019 Jan 22 ( I mean it does not contain data from 1951 to 1969 )
The 'main' table ( alldata ) on meteotemplate contains only these fields ( and we should import all these fields if available ):
Date Time, T ,Tmin, Tmax, H, D, W, G, B, RR, R, P, S, A ( metric units )
P.P.S.
Other data may be imported in a 'second pass' to the extra table ( alldataExtra )
Posted: Sun Feb 07, 2021 11:49 am
by marcelh
Thanks for the reply.
I'll remove all rows which are not used and give it another try.
Posted: Sun Feb 07, 2021 4:34 pm
by marcelh
I removed all extra rows and empty or false values. Still no luck ...... :cry:
Posted: Sun Feb 07, 2021 6:15 pm
Ok, but you have to add a couple of heading rows:
- first row is the column name
- the second row is the unit of measure of the column ( I mean °C, Km/h, hPa... )
