I got my NEST Cams working!
Posted: Fri Jan 08, 2021 4:02 pm
Hi all,
If you're having problems streaming your NEST cams, or using the Webcam Block, I got mine working with Meteotemplate using a blank block and used a frame to display the images. I have two cams and both are working flawlessly. After the <style> tags you can add:
<iframe type="text/html" frameborder="0" width="320" height="180" src="https://video.nest.com/embedded/live/XX ... autoplay=1" allowfullscreen></iframe>
Of course, replace the XXXXs with your Public key!
Check it out at http://portcoquitlamweather.ca
