Indoor T/H data no longer tabulates or plots after a specific date/time
Posted: Wed Jun 30, 2021 10:44 pm
MT v18.0, indoor temperature and humidity block v7.0, station data v10.0, indoor data v4.0 (all current).
I have 2 separate weather stations and MT installations, each of which reports the Indoor T/H.
The Indoor Conditions of the Weather Station Data section will not display or plot any data after 0525h on June 24 (7 days ago) for both locations! The current T/H is displayed in the indoor block, and I have confirmed that the extra sensors data bases for both locations contains valid data (nothing unusual after 0525h) at 5 min intervals that are up to today by viewing through the MT admin and directly parsing the SQL db on my web host. I ran SQL diags and repair operations, both with normal results. All days prior to June 24 plot and tabulate normally. Doesn't matter if I use Firefox or a chromium browser.
So both MT installations stopped data graphing and tabulation at the same time, but valid and accurate data is successfully uploaded and populated to the db. Any ideas what went bad?
Thank you.
Thank you.
