blocks and plugins
Posted: Mon Sep 25, 2017 6:17 am
by al60
Hello everyone,
The update to version 16 is perfect, all the tests are green.
On the other hand, in the installation of blocks and plugins I do not have the button "install new blocks"
during the update I have re-registered in the panel general configuration
Thank you for your help
(google translat
Re: blocks and plugins
Posted: Mon Sep 25, 2017 8:13 am
by Johnny
Hi Alain, just a thought after doing the update, did you go to your control panel and under the 'Administration' section go to 'Main Setup' scroll right to the bottom and click 'Save'
Posted: Mon Sep 25, 2017 9:11 am
by al60
I clicked on "save" in the "Main setup" but it did not correct the problem.
thank you for your help
Posted: Mon Sep 25, 2017 8:56 pm
by Thomas
Hi
We have same host (OVH) and all update functions do not work (and never worked)
The script can not retrieve versions of blocks / plugins ...
OVH blacklisted connections to meteotemplate ?
Meteotemplate have blacklisted OVH?
Posted: Mon Sep 25, 2017 9:39 pm
Could be both to be quite honest, Im using external webhosting too, I have no control or overview of their firewall rules.
Are you using https?
Posted: Fri Sep 29, 2017 8:58 pm
by Thomas
my webhosting tells me to add a user agent to use file_get_contents fonction.
Posted: Fri Sep 29, 2017 9:12 pm
by Jeffm5690
Hey there Thomas.
What does that mean?
Sorry I’m not a php expert...
