hi from Amsterdam
Posted: Sun Sep 12, 2021 11:15 am
by pd3lkn
hi ther just a newbie on this template
trying to set up my station
this is a big struggle for me cant get it to work pfff
greatings from Amsterdam
Re: hi from Amsterdam
Posted: Sun Sep 12, 2021 11:35 pm
by LOBWX
Hello from California.
Stick with the template you WILL get it working.
Posted: Mon Sep 13, 2021 11:01 am
Welcome.
For the configuration of meteotemplate you can proceed in steps:
1) database update ( I see last update is yesterday 20:49 from cumulus, but it seems ok )
2) install the blocks you want to use ( I see in your homepage/blocks directory there is no block installed )
3) configure the homepage layout
For step 3) in meteotemplate control panel -> homepage setup:
( attached image ) you can see on the top all the blocks installed and in the 3 columns ( my layout is 3 columns ) you can insert the name of the blocks you want in the order you prefer
After this you should take a break ; - )
- homepage.png (107.15 KiB) Viewed 17733 times
