Server migrated to new SS gauges no longer work
Posted: Tue Sep 21, 2021 1:15 pm
by BobW55
My hosting site just switched servers on me an now my SS gauges no longer work.
When I use the test function from the template Admin page everything has a green check box.
I know I am missing something stupid.
Re: Server migrated to new SS gauges no longer work
Posted: Tue Sep 21, 2021 2:48 pm
by Daali
is /template/homepage/blocks/ssGauges/ssGaugesBlock.php actually there? I see the Config.txt and index.php is, but get 404 trying to call it alone.
Posted: Tue Sep 21, 2021 4:52 pm
I see your site is 'offline' since 2021-09-18 07.55
Is cumulus updating correctly the new server?
Posted: Tue Sep 21, 2021 6:38 pm
by Daali
davidefa wrote: ↑Tue Sep 21, 2021 4:52 pm
I can't find anything wrong really. I think it fails at the mysql portion of the php, which could be because the mysql data is too old or an issue with the migration.
Posted: Tue Sep 21, 2021 8:24 pm
by BobW55
Yes cumulus is updating.
- snip1.JPG (58.82 KiB) Viewed 20927 times
Posted: Tue Sep 21, 2021 9:12 pm
You should have a cron job calling update/update.php, is it still active ( maybe it was deactivated during the server migration )?
The cache/apiLog.txt timestamp is 2021-09-18 08:00:42 ( your local time ) this means that api.php has not been called ( by update/update.php ) since then.
Posted: Tue Sep 21, 2021 9:35 pm
by BobW55
Posted: Tue Sep 21, 2021 10:33 pm
Try calling 'manually'
http://www.melvinweather.com/template/u ... ?password=*****
to see if it returns any error
Posted: Wed Sep 22, 2021 3:49 am
by BobW55
Ran with SUCCESS
Do Have my page showing online now but still no update to SS Gauges.
Have sent email to my web host.
Posted: Wed Sep 22, 2021 4:03 am
by BobW55
Rewrote the cron job, now its working....
Posted: Wed Sep 22, 2021 8:54 am
The cache/apiCache.txt ( which logs the values to be written in the database, it is cleared every 5 minutes ) shows the last 3
calls to api.php where on ( your local time ) :
"2021-09-21 23:46:03",
"2021-09-21 23:47:53",
Posted: Wed Sep 22, 2021 12:40 pm
by BobW55
Waiting on my hosting site.
Cron job is correct, and will execute with success if manually run.
Something on my hosting site is not allowing for that. I have placed a service ticket with them.
Funny Meteotemplate has been running for years without issue. When you run into one, you forget what you did to set it up in the first place.
Posted: Wed Sep 22, 2021 3:20 pm
by BobW55
SOLVED:
Not sure what the issue was, something my hosting site did, but up and running now.
They had me write the cron job differently, but that still did not correct it.
ended up with the original cron job.
Go figure.
Posted: Wed Sep 22, 2021 3:40 pm
Yes, that the kind of things that make me nervous
Posted: Sat Nov 13, 2021 6:41 am
by leonrossouw
I have several meteotemplate web sites one of which I have just migrated to a new host.
Everything works apart from the ssGauges ...they do not load at all.
I have gone through all the posts on this forum and to me there is no obvious answer.
I have reinstalled bith the ssGauges block and steelseries plugin.
Any suggestions ?
Leon Rossouw
Posted: Sat Nov 13, 2021 9:19 am
I had a problem with the steelSeries plugin,
resolved with this mod.
(Please provide a link to your site )
Posted: Sat Nov 13, 2021 1:53 pm
by leonrossouw
Hi and thank you,
I have installed the mod steelseries plug-in...no luck yet.
See my link to web site :
http://cannonrocksweather.com/template/indexDesktop.php
Leon.
