A couple more plugin errors...
Posted: Wed Nov 17, 2021 1:42 pm
by WessexWeather
I've noticed that the Jet Stream plugin is no longer displaying data, and the Night Sky plugin no longer produces a Night Sky map (the Sky Forecast still works fine).
Hopefully it's just a data source change issue. Could these be updated perhaps?
Re: A couple more plugin errors...
Posted: Thu Nov 18, 2021 10:18 pm
The jet stream is using images from http://squall.sfsu.edu, which, if I understand correctly is no longer active ( https://www.comdurav.com/sites/squall-s ... 7505ba1066 )
We should find a different source for the jet stream images.
Found these ( but not sure if are ok, and which to choose )
https://wxcharts.com/?panel=default&mod ... kewtstep=0
http://wxmaps.org/fcst.php
The night sky chart seems to have problems with the https server ( not sure ), changed the source to an https one
