Database Laglene
Posted: Thu Nov 25, 2021 6:26 pm
by Laglene
Bonsoir,
Je ne puis envoyer le dossier en messagerie personnelle , je l'envoie sur newtopic
Bonne réception
Merci à vous Davide
Didier
Re: Database Laglene
Posted: Sat Nov 27, 2021 2:03 pm
I sightly modified the txt file ( joined the 2 heading lines, and converted wind bearings from string to number format ).
- copy the file to your admin folder and extract it
- in the meteotemplate control panel -> 'Data Import' set as following
Posted: Wed Dec 01, 2021 9:01 am
by Laglene
Hello Davide,
First of all, I am very grateful for the help you give me and I thank you for it. I have a problem loading the file. I attach two screenshots. The first for the settings in the general configuration and the second for the error message after the test. What should I do? looking forward to reading you I wish you a very good day.
DidierImage
Posted: Wed Dec 01, 2021 9:12 pm
In the first screenshot I posted I mistakenly set URL: 'Database weather Laglene Year 2021.txt'
You should set URL: 'Database weather Laglene Year 2021a.txt' (i.e. the file I modified, with wind direction in degrees )
While I was trying to verify if the file was in your admin directory I was blacklisted by your server intrusion detection system
Posted: Thu Dec 02, 2021 12:08 am
by Laglene
Bonsoir Davide,
J'ai toujours le même message d'erreur, il refuse le chargement à cause de la date et l'heure.
Voici le chemin que je lui donne sachant que le fichier Database weather Laglene Year 2021a.txt se trouve dans le dossier install : http://meteogalargues.monespace.net/template/install/
Posted: Thu Dec 02, 2021 12:29 am
Ok, if the text file is in the install directory set URL: '../install/Database weather Laglene Year 2021a.txt'
If you click the 'Show filed numbers' button does it show as in the second image?
Posted: Thu Dec 02, 2021 11:09 am
by Laglene
:D Hello Davide,
Great, it works thanks to your valuable advice.
I am very happy to have been able to restore part of the history because the other part has disappeared with the breakage of the hard drive.
Thank you again a thousand times for your help.
I would also like to thank José Luis for all his help.
You are amazing.
Didier
Posted: Wed Dec 15, 2021 11:45 am
by johnathan
A software development service can handle all aspects of the development process. It can handle network systems, test the software, and manage various IT functions https://mlsdev.com/blog/53-how-much-doe ... mobile-app. For example, a software developed for a business will be able to collect and analyze data about its customers. It can increase sales and improve customer retention. It should be easy to use. The development service will also be able to provide support for the system. This will save you time and money and make your software compatible with other systems.
Posted: Thu Jan 13, 2022 1:31 pm
by Laglene
Bonjour, merci beaucoup pour les infos. Bonne journée
