Block current
Posted: Mon Sep 25, 2017 5:42 pm
by nitrx
Hi how do I disable UV in the block current conditions I've no solar nor uv sensor.
Thanks in advance (url
http://apeldoornmeteo.nl )
Ron
Re: Block current
Posted: Mon Sep 25, 2017 5:58 pm
by Johnny
Hi Ron, if you don't have a solar sensor, go to the Administration section of your site, click on Main Setup and scroll about a quarter of the way down the page until you see Solar Sensor and change the setting to 'No'
Re: Block current
Posted: Mon Sep 25, 2017 6:05 pm
The reason you are seeing this is because whichever means of update you are using, is actually sending UV data (as 0, but it should not send anything, otherwise the template thinks you have this sensor).
Here is raw data sent to the API:
http://apeldoornmeteo.nl/meteotemplateLive.txt
You can see UV there
Re: Block current
Posted: Mon Sep 25, 2017 6:07 pm
by nitrx
Johnny wrote: ↑Mon Sep 25, 2017 5:58 pm
Thanks for thinking with me, it was alreay set to 'no' , I saved again but still uv shows up
Ron
Re: Block current
Posted: Mon Sep 25, 2017 6:08 pm
by nitrx
Jachym wrote: ↑Mon Sep 25, 2017 6:05 pm
Aha I now the problem I've a WH3080 so uvi data is sent, unfortunally the sensor is broken so no data comes in
well have to live with it , thanks anyway.
