updated radarEU block ( radarSat24 )
Posted: Thu Feb 10, 2022 2:25 pm
ver 3.2
- added options to configure the 2 maps ( left and right map ), single map is supported too
- added option do define initial map type and timezone
NOTE
I think that this block should be called radarSat24 as it shows maps for Europe And Africa ( currently America, Asia and Oceania not working )
Wondering if may be useful to add a second drop down box to select map type independently for left/right map
Re: updated radarEU block ( radarSat24 )
Posted: Thu Feb 10, 2022 6:49 pm
by Jolumarali
update completed
thank you davide
Posted: Fri Dec 22, 2023 7:55 am
by djpoppy
Does it still work for you? My radar doesn't load anymore...
Posted: Fri Dec 22, 2023 11:28 pm
Yes, sat24 has changed, so need to update the block
Posted: Sat Dec 23, 2023 6:01 pm
Quick and dirty block update:
ver 3.3
- changes due to sat24.com changes
- available only rain radar and satellite maps
- maps are now provided by meteox.com and cover the whole world ( so radarEU is not that appropriate any more )
- rerun the setup as parameters are completely different
- you can still setup one or two maps
- radarEU01.png (366.84 KiB) Viewed 33003 times
To center a map 'on a country', fill in the first parameter ( which is the 2 chars ( always lower case ) code of the country, for example: it for Italy )
- radarEU03.png (29.01 KiB) Viewed 33003 times
To center a map 'on a location', fill in the second parameter ( see
https://widgets.meteox.com/en-GB )
Only include one of these two parameters ( if you include both only the 'country code' will be considered ).
- radarEU02.png (182.13 KiB) Viewed 33003 times
Here is the block ( max 3 attachments per post )
ver 3.4 ( Dec 30, 2023 )
- bug fix ( location on regional/right map )
- corrected dropdown menu position
- added 'default setup' for new installations
Posted: Wed Dec 27, 2023 5:09 pm
by djpoppy
Thanks @davidefa
Posted: Sat Dec 30, 2023 7:30 am
by giando11
Hi davide, on my site the location doesn't work. Zoom only on Rome. The code that i setting are correct but zoom only to rome
Posted: Sat Dec 30, 2023 3:13 pm
The updated version, on my previous post, should fix the issue you noted
Posted: Mon Jan 15, 2024 8:57 pm
by Weerstation Bolsward
thank you
Posted: Thu Jan 18, 2024 8:56 pm
by Weerstationwoerden
Thanks it's works fine
