Import database
Posted: Mon Mar 07, 2022 11:41 am
by Saszalez
Hello. I have a significant station history that I would like to import into the template. The recordings are every 10 minutes. I did a test to see if I could import the data from the .txt file that WL generates. My question comes about the temperature data since WL saves the average temperature, the maximum temperature, and the minimum temperature every 10 minutes. When selecting the import, I only have to choose which is the temperature column, and it fills the database putting the average temperature to the maximum temperature and the minimum temperature. Since those two columns exist, is there any possibility of choosing in the script which are the maximum and minimum temperature columns to be able to complete the database with greater precision?
Re: Import database
Posted: Mon Mar 07, 2022 10:37 pm
You can try this mod ( not fully tested ), unzip it in admin directory.
If it does not work, please post the data to import ( or at least a part of it )
Re: Import database
Posted: Tue Mar 08, 2022 3:37 pm
by Saszalez
Thanks, it worked perfectly for me; even the wind direction, which the data logger exports in letter format, did the conversion to degrees correctly.
