partnerstations block
Posted: Sat Mar 19, 2022 6:54 pm
by dtwrlewis
Doesn't seem to be working anymore. Despite trying to change settings etc I can't get it to display values. I notice that the demo version isnt updating either. http://www.meteotemplate.com/template/i ... erStations
Re: partnerstations block
Posted: Sun Mar 20, 2022 7:51 am
by Jolumarali
Hello
you add the stations in the settings2.php file and do not forget to empty the cache file each time this file is modified.
good installation
Posted: Sun Mar 20, 2022 1:22 pm
by dtwrlewis
Thanks Jose, I did the edit settings2. php and empty cache, but still not working. I notice in your page your partners block - Bailleval and Brno - dont work. I presume I have a typo somewhere - i'll keep looking
Posted: Sun Mar 20, 2022 3:04 pm
You need to set your wu api key in the meteotemplate main setup
Posted: Sun Mar 20, 2022 8:50 pm
by dtwrlewis
That works. Thank you!
Posted: Sun May 29, 2022 11:27 am
by amonphi
davidefa wrote: Sun Mar 20, 2022 3:04 pm You need to set your wu api key in the meteotemplate main setup
Hi Davidefa,
Although I set the settings2.php file, empty the cache and reset the wu API key, still does not want to know, the values remain at 0. I don't know why
Posted: Tue May 31, 2022 6:38 pm
by MonyMony
Take a look at viewtopic.php?f=56&t=1823&p=9155&hilit= ... tion#p9155
Not sure if the block posted for download has the API path settings updated to what Weather Underground now expects.
Posted: Thu Jun 02, 2022 1:31 pm
amonphi wrote: Sun May 29, 2022 11:27 am
Hi Davidefa,
Although I set the settings2.php file, empty the cache and reset the wu bees key, still does not want to know, the values remain at 0. I don't know why
The block posted by José Luis contains the mods by ManyMany, but I see your block cache/stationData.txt file has only 0 values.
I obtain similar result changing my wu api key ( in the main setup, section services ) with an invalid one.
So check that your api key is correct
You can test the validity of your api key using the following link ( substitute the YOURAPIKEY with the correct value ):
https://api.weather.com/v2/pws/observations/current?stationId=IFANO20&format=xml&units=e&apiKey=YOURAPIKEY
Posted: Thu Jun 02, 2022 5:55 pm
by amonphi
davidefa wrote: Thu Jun 02, 2022 1:31 pm
Hi Davidefa,
After reading your answer I went to the API Key and the services and apps that I use with that, they all work except partnerstions, then I went to check on Wunderground and I noticed that the API Key had expired on 07/10/2019 (but All so far worked, I don't explain it).
I created another in doubt but, despite this, until I updated The Block Posted by José Luis Contains the Mods by Manymany, he kept not working!
Now I have canceled cache and everything is ok thanks
Posted: Thu Jun 02, 2022 5:56 pm
by amonphi
MonyMony wrote: Tue May 31, 2022 6:38 pm Take a look at viewtopic.php?f=56&t=1823&p=9155&hilit= ... tion#p9155
Thanks I saw and with your mod now it works!
Posted: Thu Nov 23, 2023 1:45 pm
by MeteoElMasnou
Jolumarali wrote: Sun Mar 20, 2022 7:51 am Hello
good installation
It didn't work for me and with your block and placing the WU API working correctly.
Thank you José Luis
