Extreme block update
Posted: Fri Apr 22, 2022 4:43 pm
by Saszalez
It would be interesting to be able to add a couple more stats to the block, such as:
- Average of the maximum
- Average of the minimum
- Highest lows (being able to see the highest lows)
- Lowest highs (being able to see the lowest highs)
Would it be complicated to print?
Re: Extreme block update
Posted: Sat Apr 23, 2022 12:33 pm
Yes, it can be done. How would you do this:
a) expanding the 'absolute' option, adding two more sections ( avg. min / avg. max and highest min / lowest max ), longer block, but easier to compare
b) adding one or two separate option
Posted: Sun Apr 24, 2022 2:29 pm
by Saszalez
Option "a" sounds good, it is true that the block would be longer, but the comparison is worth it.
Posted: Mon Apr 25, 2022 10:16 pm
ver 2.1
- added absolute average and highest min values
- added absolute average and lowest max values
- corrected the sorting error of dew point
The wording ' min min', max min'... is quite confusing but in the language file did not find high/low definitions
Re: Actualización de bloque extremo
Posted: Sun May 08, 2022 3:38 pm
by Saszalez
Hi sorry.
But looking at the block carefully, I have doubts about each value.
- Min Min and Max Max are the absolute minimum and absolute maximum values, that is, the lowest minimum and the highest maximum.
- Avg Min and Avg Max are the minimum of the averages and the maximum of the averages, but what averages? Is this value not equal to the average temperatures (another option)?
- Max Min and Min Max are the highest minimum and the lowest maximum. If so, it should be in reverse order, I think.
After putting this, I don't know if it might be better to add different options to make the title clearer and not expand the absolutes option.
