webcamRename plugin URL disappear.
tobydude
Software: Weatherdiaplay
Post by tobydude » Fri Dec 09, 2022 2:03 pm
Hi.
Why does "Renamed image name / Input image URL" and "Output image name" just disappear in the plugin webcamRename ?
Have happened several times.
Re: webcamRename plugin URL disappear.
Post by davidefa » Sun Feb 05, 2023 8:49 pm
When does this happen? Every time you run the setup?
Those should be the default values, this could mean the settings.php file is corrupt.
Could be helpful if you could zip the entire plugin directory ( include the awebcamRename.php script in file load/crons ).
tobydude
Post by tobydude » Sun Feb 05, 2023 9:51 pm
It happened again today.
You can see the webcaam picture on weatherpage don´t change.
All the settings are empty.
Will look at it tomorrow.
tobydude
Post by tobydude » Mon Feb 06, 2023 4:42 pm
It has happened 4 or 5 times. A few monts since last time it happened.
Fortunately the web browser cache stores the settings. (Opera)
So just by clicking in the empty fields in the webcamRename plugin settings, the cache recover the settings.
zipped-forumfiles.rar
(21.6 KiB) Downloaded 855 times
johnathan
Station model: wh1080
Post by johnathan » Mon Feb 20, 2023 10:53 pm
If you don’t have the technical skills to build a travel app, there are a number of companies and services that offer app development services. At MLSDev, we offer a wide range of app development services that can help you create the travel app you need. Our team of experienced and skilled developers is ready to help you create the solutions you need to succeed web development
