Rain data weewx-> meteotemplate
Posted: Mon Feb 06, 2023 10:20 am
by wifi75
hello everyone I have weewx 4.10.1 installed, which via api sends data to meteotemplate.
the only data that I don't see are those of the rain. in fact the sensor is at zero.
Obviously in weewx the rain data is there.
what can I do?
Re: Rain data weewx-> meteotemplate
Posted: Mon Feb 06, 2023 10:32 am
Please post a link to your site so we can take a look.
If weewx sends data to meteotemplate calling api.php you can take a look at cache/apiLog.txt ( it logs and decodes the last call to api.php script )
Take a look at the rain data passed in:
- apilog02.png (51.74 KiB) Viewed 59343 times
and the rain data as parsed:
- apilog03.png (59.87 KiB) Viewed 59343 times
I see you have a gw1000, in this case you can also use the
ecowitt plugin to receive data directly from the gateway
Posted: Mon Feb 06, 2023 10:53 am
by wifi75
davidefa wrote: ↑Mon Feb 06, 2023 10:32 am
here is my link and log in attachment
https://meteo.iu3cyv.eu/template
here link to weewxc with data rain:
https://meteo.iu3cyv.eu/weewx/year.html
I can't use the plugin in meteotemplate because ecowit is set to send data to Home assistant. so I must necessarily get them from Weewx.
Posted: Mon Feb 06, 2023 11:29 am
Ok, your rain ( R field ) and rain rate ( RR field ) are present but 0 ( so weewx is sending, in this moment, 0 as rain and rain rate )
Is your station reporting a total daily rain > 0?
In this case, my first guess, is there is something wrong in the weewx 'sending configuration'
Is there a weewx log of the data sent to meteotemplate?
- apilog04.png (66.21 KiB) Viewed 59328 times
I noticed also that last rain recorded by your station is on april 2022, did you change anything after that date?
- rain08.png (505.09 KiB) Viewed 59328 times
Posted: Mon Feb 06, 2023 11:34 am
by wifi75
davidefa wrote: ↑Mon Feb 06, 2023 11:29 am
I don't know if there is a log... what can I check?
it worked in 2022, then after an update it didn't work anymore... how can I alter the weewx data by simulating rain?
Do you have any ideas on how to figure out where the problem is?
Posted: Mon Feb 06, 2023 11:56 am
I'd say, make a manual click of the rain sensor ( pouring a small amount of water in the rain sensor funnel for example ).
Check on the wsview that the rain is recorded.
Recheck the cache/apiLog.txt if the rain is reported correctly to meteotemplate in the R field.
If not a misconfiguration in weewx is the more likely candidate.
Post also the configuration files you use in weewx.
I'm not a 'weewx man', never used it
P.P.S. How do you 'feed' your station data to weewx? Are you using this
weewx driver?
Are you using the custom upload of the gw1000?
If not you could use the custom upload to send data to meteotemplate ( and the problem will be automatically solved )
P.P.P.S.
Weewx should log on the system log: /var/log/syslog
Posted: Mon Feb 06, 2023 12:41 pm
by wifi75
davidefa wrote: ↑Mon Feb 06, 2023 11:56 am
weewx driver?
this is my driver on weewx:
https://github.com/gjr80/weewx-gw1000
then weewx sends the data via api to meteotemplate
how do you mean custom upload to send dato to meteotemplate?
Posted: Mon Feb 06, 2023 12:44 pm
In the wsview app go to the online services setup configuration, and check the last service 'custom upload' if it is enabled.
If it is disabled you can use it to send data to your meteotemplate.
- custom_upload.jpg (44.55 KiB) Viewed 59314 times
Posted: Mon Feb 06, 2023 12:49 pm
by wifi75
I can't send data from gateway to meteotemplate, because gateway is configured to send data to home assistant.
