new netAtmoNetModule ( netAtmoNet plugin companion )
Posted: Mon Oct 23, 2023 7:30 pm
This block is to be used in cpnjunction of the netAtmoNet plugin.
Shows the module's status.
ver 1.0
- initial release ( based on netAtmoModules ver 1.0 )
- blocknetatmonet01.png (44.4 KiB) Viewed 56677 times
Re: new netAtmoNetModule ( netAtmoNet plugin companion )
Posted: Fri Nov 03, 2023 9:07 am
by tobydude
Have installed netAtmoModules ver 1.0.
When I click on "Edit settings" on the block netAtmoNetModules I em sendt to the "Moon phases Settings".
Same with the block "norwayAlerts". When I click on theese two blocks settins, I em semdt to the "Moon phases Settings".
So it is difficult to get to the settings of the block netAtmoModules.
Posted: Fri Nov 03, 2023 10:31 am
It is a small bug of meteotemplate 19.0, that shows ( in some cases ) the 'edit settings' even for blocks that do not have a settings ( as the norwayAlerts and netAtmoNetModules ).
Extract the following script in the admin directory, it will ( hopefully ; - ) solve the issue.
Posted: Fri Nov 03, 2023 12:50 pm
by tobydude
Hate to bother you with minor details, but after installing blockSetup_19.0a in the admin directory, the "Edit settings" disappeared for netAtmoNetModules and norwayAlerts.
Posted: Fri Nov 03, 2023 1:11 pm
Yes, that's correct, both modules don't have any configurable option.
Posted: Fri Nov 03, 2023 2:04 pm
by tobydude
Problem solved, then. Thank you.
Posted: Thu Dec 07, 2023 3:28 pm
by El_Viejo
This is the error message that appears.
However the plugin works correctly and the data is updated.
Initially, I thought that the cause was the removal of the block and plugin primitives ("netAtmo" and "netAtmoModules") to avoid errors.
But I think the cause is something else and I am not able to find it.
Posted: Thu Dec 07, 2023 3:47 pm
by tobydude
El_Viejo wrote: ↑Thu Dec 07, 2023 3:28 pm
I got the same error.
Posted: Thu Dec 07, 2023 10:22 pm
That message appears when the plugins/netAtmoNet/netAtmoLive.txt file does not exists, but in the case of tobydude I can see the file exists and is updated, and opening the block maximized (
https://fjærvollan.no/template/indexFul ... NetModules ) works.
My guess is that the php function that check the file ( file_exists ) fails for some reason.
In this modified block I removed this check ( which is also unnecessary ).
Sometimes something strange happens, for example on my notebook I have 3 different meteotemplate test sites running on php 8.2.4 on 3 different directories ( template, template1 and template2 ), same server, but on template2 I have the nasty message that the cache directory is not writable, even if it writable and files are created regularly.
Can't understand why...
Wondering why both of you have this problem in the same time ( the netatmo rebellion : - )?
Posted: Fri Dec 08, 2023 10:55 am
by El_Viejo
Installed V1.1. Now a different message appears.
"Datos actualmente no disponibles" = "Data not currently available"
davidefa, that's a lot of lines of code to review.
Don't dismiss the Netatmo rebellion either. The first plugin suddenly stopped working, with no apparent cause. Now I'm having small problems with the plugin page refresh, something that didn't happen before.
Thank you very much for your interest.
Posted: Fri Dec 08, 2023 11:36 am
by tobydude
I got it to work. Not sure what I did.
Checked all (client id and client secrets)
Changed the block to "multipleBlock(netAtmoModules,50)" , saved, and then back to "multipleBlock(netAtmoNetModules,50)".
Sounds corny but than it worked.
Bottom left at
Posted: Fri Dec 08, 2023 3:59 pm
by El_Viejo
In my case, the trick has not worked.
Posted: Fri Dec 08, 2023 5:05 pm
- If you point your browser to the block maximized does it show correctly?
http://ip_of_the_raspberry/template/indexFull.php?block=netAtmoNetModules
- does the file template/plugins/netAtmoNet/netAtmoLive.txt exist?
you can reach it with your browser too at the following url:
http://ip_of_the_raspberry/template/plugins/netAtmoNet/netAtmoLive.txt
Posted: Fri Dec 08, 2023 7:17 pm
by El_Viejo
In the first IP, the text "Data currently not available" appears at the top of the full screen.
On the second IP the message "Not Found" appears.
On my server, the file "indexFull.php", is dated 08/06/19 06:33 and 130 lines.
The "netAtmoNet" folder has 7 PHP files and only one TXT file. It is the one that registers version 1.4.
Again, thanks for your patience.
Posted: Fri Dec 08, 2023 8:49 pm
by tobydude
Have you tried to set your PHP version on your template server to version 7.4?
Posted: Fri Dec 08, 2023 9:01 pm
Also verify that your plugins/netAtmoNet folder has the 'right permissions', so that it is writeable by php.
The question is: what is the right permissions?
It depends 'on the server', on a server of mine the right permission is 0755 for folders and 0644 for files ( on another is 0755 for both folders and files )
In the case of tobydude the file ( netAtmoLive.txt ) was there, but not recognized somehow, in your case the file is missing.
Posted: Fri Dec 08, 2023 9:02 pm
by El_Viejo
I am using PHP 7.4.28
Posted: Fri Dec 08, 2023 9:07 pm
by El_Viejo
I have used these Debian commands on my Raspberry Pi 4
sudo chmod -R ugo+rwx /var/www/html
sudo chmod -R 777 /var/www/html
Posted: Fri Dec 08, 2023 9:12 pm
by tobydude
Also check that your crontab is ok.
The "updateNetAtmoNet.php" should be in the "/public_html/template/load/crons" folder.
Posted: Fri Dec 08, 2023 9:15 pm
by El_Viejo
At this moment I just became aware.
I have not used these commands when uploading the new blocks and plugins to the template.
Now I do it.
Posted: Fri Dec 08, 2023 9:16 pm
by El_Viejo
It works.
My apologies for this oversight.
Thank you for your patience.
Posted: Fri Dec 08, 2023 11:21 pm
Good, the fact is that zip archives contain also files flags.
For some reason ( which I don't understand ) sometimes when unzipping achives the files extracted are marked read only ( this happens not only on linux machines, but on windows too ).
I found this 'the hard way' : - (
