updated forecast block
Posted: Sun Dec 24, 2023 11:40 am
ver 9.5 ( http://www.davidefabbri.net/files/meteo ... st_9.5.zip )
- substituted darksky forecast ( not available any more ) with openweathermap.org
Settings:
In 2) you need to insert your openweathermap.org key ( if you have not already inserted in the main meteotemplate in place of the darksky api key )
In 1) insert the cityid, retrieved in this page https://openweathermap.org/widgets-constructor as shown below
Same for the id to insert in 3)
Re: updated forecast block
Posted: Tue Jan 09, 2024 6:07 pm
by atari
For some reason it not working whit my config
Posted: Tue Jan 09, 2024 11:23 pm
Does it show any error?
After installing the new block and running setup, remember to delete the cache ( or you will continue to see previously cached data, until cache expires ).
If this does not work, I could test the block on your server, but a need a write access to your server ( via ftp or a file manager ).
Posted: Wed Jan 10, 2024 3:28 pm
by steph
perfect for me a big thank you :)
Posted: Thu Jan 18, 2024 7:37 pm
by Oscarmr
I'm trying to download the zip but the link doesn't work
Posted: Sat Jan 20, 2024 8:15 pm
by Gary
@Oscarmr
The link to the zip works for me. I am using Chrome.
I found Chrome tries to block the download as it thinks the zip file might be unsafe - I have to tell chrome to "keep it"
When using Firefox browser the file downloads with no issues.
Hope that helps a bit
Gary
Posted: Sun Jun 16, 2024 1:19 pm
by dtwrlewis
Thanks for this updated forecast block. Works well for me.
