import data from WU
Posted: Sun Jan 14, 2024 10:43 am
Hi to you all
I want to import all data from my weather station to the database from this template
Only I lost all data from the weather display some time ago
But I see all my data is on weather underground
Is there a way for download all data from weather underground to the data base from the template
I see into the screen from DATA IMPORT
( If you have the possibility to choose, then only use the WU option if absolutely necessary. It is the least reliable and also takes the longest time. Use data import from a file if possible.)
so it there a way for import the data from weather underground ore not ??
