PROBLEM with Outlook" plugin in the "Forecast"
Posted: Thu Feb 08, 2024 9:24 am
by F1SKF
Good morning,
The "Outlook" plugin in the "Forecast" menu in "Weather" no longer displays anything!
What is the problem ? Thank you for your help.
Sincerely
Hervé
http://pecouba.fr/IMAGE/Capture%20d'%C3 ... 100753.png
Re: PROBLEM with Outlook" plugin in the "Forecast"
Posted: Sun Feb 11, 2024 10:39 pm
by Laglene
Good evening, I looked on other sites and a priori the problem is general. I'm in the same situation as you. Davide, as is often the case, may have the solution.
But if a member of the community has the answer, don't hesitate.
Looking forward to
Posted: Mon Feb 12, 2024 10:05 pm
by lemimi
hello,
En tout cas, cela fonctionne nickel chez moi :
https://lemimi.fr/template/pages/forecast/index.php
Bonne soirée... Michel
Posted: Mon Feb 12, 2024 10:38 pm
by Laglene
Good evening,
Indeed it seems to work with the old OpenWeather APIs.
The news has problems...
Posted: Thu Feb 15, 2024 8:33 pm
by F1SKF
Good morning,
How to recover the working plugin?
Sincerely.
Hervé
https://meteo88.pecouba.fr/
Bonjour,
Comment récuperer le plugin qui fonctionne ?
Cordialement.
Hervé
