Setting solar radiation in main setup to 'yes' makes data disappears
Posted: Wed Aug 14, 2024 3:08 pm
by Meteo Heijningen
Since a couple of days I have a new weatherstation which also measures solar radiation. The problem is when I set the solar radiation in the main setup to 'Yes' all data in the block 'Current' disappears! Setting this to 'No' again all data is back. Same for the block Stationdata as soon as I add the 'S' the data is gone. I can only see the solar radiation in the block 'current', I've added the 'S' and the solar radiation is visible along with the corresponding data.
I've no idea why this is happening so would be glad to get some help.
Eddy
Re: Setting solar radiation in main setup to 'yes' makes data disappears
Posted: Wed Aug 14, 2024 4:31 pm
by FSC830
Strange,
Can you check your database values if all are correct when "solar" is enabled?
You will see this in control panel - database - edit data.
Posted: Wed Aug 14, 2024 6:51 pm
by Meteo Heijningen
I just set the solar radition to 'yes'. Values in the block current not visible, and edit the database, all values looked ok but strange enough the solar radiation field was empty no values at all. So next question is where is the solar radiation stored as Meteobridge is sending the value cause if I goto apisetup its there and!!!!
Posted: Wed Aug 14, 2024 7:02 pm
by Meteo Heijningen
It looks like it's working now I did a database update and put the solar radiation to yes and all values still there, also in the station data block including solar radiation.
Problem solved
Thanks for the help
Posted: Thu Aug 15, 2024 3:25 am
by FSC830
Great to hear.
Enjoy.
Posted: Thu Aug 15, 2024 9:25 am
by Meteo Heijningen
Apparently not completely solved as this morning at 07:20 the solar radiation value is not stored in the database anymore, fields are completely empty! The correct value is still displayed at the homepage and in the blocks, I checked meteobridge nothing wrong there.
Wondering why the value is not stored anymore, anyone any idea?
Eddy
Posted: Thu Aug 15, 2024 10:08 am
by Meteo Heijningen
Also this one solved, In the main setup the max. limit for solar radiation has been set to 20, I changed it to 1400 and then the value was stored again. Apparently when a value exceeds the limit (that happened at 07:20) it's not stored anymore.
Eddy
