graphCombined -New Dec 2 2024 problem SOLVED
Posted: Mon Dec 02, 2024 9:03 pm
by Sarah R Taylor
The block graphCombined suddenly stopped working today, Dec 2 2024 on my website: https://www.owlsheadns.com/template/indexDesktop.php
with no changes from me or from my ISP that I can see. The demos at: https://www.meteotemplate.com/web/blocks.php (and select graphCombined) are also not working.
I looked both using Firefox on Win 11 and Chrome on Android.
Re: graphCombined -New Dec 2 2024 problem
Posted: Mon Dec 02, 2024 9:39 pm
by lemimi
Good evening,
Maybe try the latest version updated by Davidefa here:
https://www.meteotemplate.com/forum/vie ... =25#p13572
Michel
Posted: Tue Dec 03, 2024 1:40 am
by Sarah R Taylor
@lemini Thank you for the suggestion I try Davidefa's new version but it would not install for me. Perhaps I need instructions of exactly how to install Davidefa's version. I started this new thread because it seemed to me that my current problem was not like the one that Davidefa set out to solve.
Posted: Tue Dec 03, 2024 7:42 am
It seems you have not correctly updated the block as I can still see the 'map error' on your site ( verify that the graphCombinedBlock.php script is the one included in ver 3.0, Dec 02 2024 ):
Posted: Tue Dec 03, 2024 1:41 pm
by Sarah R Taylor
Thanks to both people who responded. I tried again to install the latest version of the block from a few days ago and it seems to be working. I think I know what my mistake was last evening. I tried to have both the old and the new version running, with different names, but it seems that didn't work. So I put the new files in the directory where the original files were (I made a backup copy) and removed an old "setup.php" file before doing Edit Settings.
I guess I will never know why the old version worked until it didn't. My hosting provider made no changes as far as I can tell. My sites are running with PHP Version 7.4.33.
Re: graphCombined -New Dec 2 2024 problem SOLVED
Posted: Tue Dec 03, 2024 9:15 pm
I think it has something to do with a higcharts change ( as the error refers to a nonexistent highcharts.map function which was previously working )
Posted: Wed Dec 04, 2024 6:46 am
by Jolumarali
Glad to see you again Davide and thank you again, Everything is working properly and thank you all :)
Posted: Wed Dec 04, 2024 7:10 am
by Alvaro Poggiani
Sono nuovo e inesperto ma, come altri, volevo esprimere anch'io la felicitĂ  di poter ri-leggere i consigli e le "istruzioni" di Davide che, pur conoscendolo solo per le gentili parole di benvenuto, ho potuto -cercandolo e leggendolo- apprendere e capire molte problematiche da lui risolte precedentemente.
Meglio viaggiare sapendo che un faro può sempre indicarti dove andare...
Grazie ancora e, forse, in anticipo
Alvaro
https://meteovarazze.it
