Good afternoon,
I have recently updated to cranberry v19.0, and wanted to share my experience...
At this moment you have to ask Jachym directly for a token to download the update or the full template, depending on what you are going to do.
First problem I ran into was that after having the token, I downloaded the full template, not the update file.
pay atention here,
https://www.meteotemplate.com/web/download.php
on the left of the page, select update for the file, then dowload it and follow the wiki instructions.
This was the first nag for me, so I had to ask for a new token. (thanks Jachym for patience and token)
Then all went seamlessly and I updated server php to 8.3.16
All well again, but having problems with the following blocks that stopped running,
astroEvents
metarCustom
metarWeather
radarPT
warningsEU
solarEclipses
weatherPortugal
partnerStations
I have seen some of them running properly on MT sites in Cranberry, so I guess I am doing something wrong.
Please if you are running those blocks OK and want to give an insight, I 'd be grateful.
If you found the post useful I will be glad as well.
Wanna have a look?
http://cerradadogrilo.scienceontheweb.n ... esktop.php
http://quintadashortas.scienceontheweb. ... esktop.php
You all have a nice time.
Updating to Cranberry
juanrpaz
Re: Updating to Cranberry
Probably it has to see with the sites being in http;//something and not in https;//something...
Not a pro, I'd be grateful any enlightment regarding the issue
I managed to install the certificate, and sites moved to https space, however I've lost the access to admin
gone to path/admin/login.php
changed template path to https and admin access regained... secure access is now solved, off-topic done...
What about the blocks that stopped running?
Kind regards,
Juan
Kind regards,
Juan
