Post-Install Issues
Posted: Thu Mar 20, 2025 7:41 am
Hi, i'm an intermediate user, and i have more than one issue after installing (and setup) meteotemplate.
My host is Aruba.it, with php 8+ and Mysql on Linux (Apache / PHP-FPM).
All checks are ok, (install/testMySql.php, install/serverCheck.php).
Main issues are:
1) When trying to open Control panel
2) When trying to update via API (success is displayed, but i've this error in php logs, and no update is made)
For the 1) i've had access to admin panel modifying the query in index.php line 41:
from SELECT DISTINCT YEAR(DateTime) FROM alldata ORDER BY DateTime
to SELECT DISTINCT YEAR(DateTime) AS year FROM alldata ORDER BY YEAR(DateTime) DESC;
it works, but this is a fix, not a solution....
For the 2) i have no idea (the get update query, custom generated is: api.php?U=1742405467&T=25.3&H=79.9&P=1000.1&W=12.6&G=19.8&R=0&B=272&S=788&UV=0&PASS=MYPASS).
I've manualy added 1 row of data just to see if something changes..
Also, i can see random errors when load other pages (with ?errors in the last part of the link), i.e.:
/template/indexDesktop.php?errors:
And this error appears with climate, astronomy, etc (i've not pasted all errors).
Finally, the DEV told me to run a query into my PhPMyAdmin:
SET GLOBAL sql_mode=(SELECT REPLACE(@@sql_mode,'ONLY_FULL_GROUP_BY',''));
result:
#1227 - Access denied; you need (at least one of) the SUPER or SYSTEM_VARIABLES_ADMIN privilege(s) for this operation
i start to think it's incompatible with this host.
Any hint, maybe from someone who uses the same hosting service?
Main issues are:
Fatal error: Uncaught mysqli_sql_exception: Expression #1 of ORDER BY clause is not in SELECT list, references column 'Sql1853116_5.alldata.DateTime' which is not in SELECT list; this is incompatible with DISTINCT in /web/htdocs/www.mysite.com/home/template/admin/index.php:41 Stack trace: #0 /web/htdocs/www.mysite.com/home/template/admin/index.php(41): mysqli_query() #1 {main} thrown in /web/htdocs/www.mysite.com/home/template/admin/index.php on line 41Code: Select all
AH02296: Unknown directive php_flag perhaps misspelled or defined by a module not included in the server configurationfrom SELECT DISTINCT YEAR(DateTime) FROM alldata ORDER BY DateTime
Warning: Undefined array key "climate" in /web/htdocs/www.mysite.com/home/template/menu.php on line 490
Warning: Trying to access array offset on null in /web/htdocs/www.mysite.com/home/template/menu.php on line 490
Warning: Undefined array key "climate" in /web/htdocs/www.mysite.com/home/template/menu.php on line 513
Warning: Trying to access array offset on null in /web/htdocs/www.mysite.com/home/template/menu.php on line 513
Deprecated: strpos(): Passing null to parameter #1 ($haystack) of type string is deprecated in /web/htdocs/www.mysite.com/home/template/menu.php on line 513
Warning: Undefined array key "climate" in /web/htdocs/www.mysite.com/home/template/menu.php on line 525
Warning: Trying to access array offset on null in /web/htdocs/www.mysite.com/home/template/menu.php on line 525
Warning: Undefined array key "us" in /web/htdocs/www.mysite.com/home/template/scripts/functions.php on line 115
Deprecated: ucfirst(): Passing null to parameter #1 ($string) of type string is deprecated in /web/htdocs/www.mysite.com/home/template/scripts/functions.php on line 162
/web/htdocs/www.mysite.com/home/template/menu.php on line 527
Warning: Trying to access array offset on null in /web/htdocs/www.mysite.com/home/template/menu.php on line 527
" target="_blank" class="digimeg-nav-item">
Warning: Undefined array key "climate" in /web/htdocs/www.mysite.com/home/template/menu.php on line 528
Warning: Trying to access array offset on null in /web/htdocs/www.mysite.com/home/template/menu.php on line 528
result:
