"Import Data" feature only processing 1st entry
Posted: Wed Jun 18, 2025 4:41 am
Hi everyone.
I am using MeteoTemplate v19, and I want to upload updated weather records from Cumulus to the server WeatherDB to fill in gaps caused by network outages.
I'm using the data import function to import the daily log files from Cumulus. My host server is on PHPv8.2.
What I am getting is:
Only the first record is processed.
Looking at importFile.php, it appears that the call (line 446) to "mysqli_query($con,$query)" never returns to the script, so nothing further gets processed. (I inserted echo commands before and after this line). I have full error reporting turned on and nothing in the error log.
Anyone else having this issue or know how to resolve it?
Many thanks!
Cheers
...Steve
Importing data from CSV/text file...
Errors will be highlighted in red...
Loading CSV/text file from https://samfordweather.com/weather/importData/combined_20250314a.txt
File loaded successfully.
No header, reading from first line.
The imported file has 41 data sets.
Import type: skip
Starting to parse data.
All ok, imported (skipped if exists): 2012-12-16 15:45
INSERT INTO alldata (DateTime,T,Tmax,Tmin,H,P,W,G,R,RR,B,S,D,A) values ('2012-12-16 15:45',33.5,33.5,33.5,38,996.00,7.0,0.0,6.10,31.00,0.0,null,17.3,34.6)Looking at importFile.php, it appears that the call (line 446) to "mysqli_query($con,$query)" never returns to the script, so nothing further gets processed. (I inserted echo commands before and after this line). I have full error reporting turned on and nothing in the error log.
else{
if($parameters['importType']=="skip"){
echo "All ok, imported (skipped if exists): ".$dateTimeFormatted."<br>".$query."<hr>";
mysqli_query($con,$query);
}Many thanks!
Cheers
...Steve
