New WindHeatmap block
Post by davidefa » Thu Jan 22, 2026 1:59 pm
This is a block similar to windVector block.
Wind is shown as a heatmap ( showing speed and direction change over time )
The 'sampling interval' is used to group the data series
ver 0.4
- added conditional definition of function count8 ( in case not already defined )
ver 0.3
- preliminary version
NOTE
You need also to modify the indexDesktop.php script adding the following line ( near line 212, after similar script tags ) and indexFull.php ( near line 77, after similar script tags ):
		<script src="https://code.highcharts.com/modules/heatmap.js"></script>
		<script src="https://code.highcharts.com/modules/coloraxis.js"></script>
windHeatmap_0.4.zip
(5.66 KiB) Downloaded 145 times
windHeatmap_0.3.zip
(5.54 KiB) Downloaded 132 times
Meteo Heijningen
Station model: Ecowitt Wittboy GM2001
Re: New WindHeatmap block
Post by Meteo Heijningen » Wed Jan 28, 2026 9:46 am
Hi David,
I've installed it but seeing no data, so for me it likes not working.
Eddy
Post by davidefa » Wed Jan 28, 2026 10:51 am
Thanks for reporting, I've updated the block ( in previous version I used a count8 function which I defined in my updated script/functions.php file, as a php 8.x quick fix )
Meteo Heijningen
Post by Meteo Heijningen » Thu Jan 29, 2026 9:13 am
Hi David,
I've installed the updated block and it's working now.
Thnx
Eddy
MeteoElMasnou
Post by MeteoElMasnou » Sun Feb 22, 2026 8:51 am
Installed and working.
Thanks, David.
