Not able to view bloomsky timelapse block
Posted: Tue Oct 03, 2017 4:34 pm
by Fraggboy
Hello.
So, I have traced it down to running the site via https. As of now, it's showing a strange error (Shown below).
- Bloomskytimelapse.jpg (53.34 KiB) Viewed 24593 times
I have tracked it down to the
bsCache.txt file. The URL's to AWS is http. When I replace all to https, it works great. I checked bloomskyTimelapseBlock.php and changed all http to https. It breaks the block.
Does anyone know of a way to modify the code so when it updates the text file, it uses https?
Re: Not able to view bloomsky timelapse block
Posted: Tue Oct 03, 2017 9:17 pm
by Fraggboy
So, I have come up with a workaround for now. I created a simple script that finds and replaces http with https every 30 minutes via cron.
sed -i 's/\bhttp\b/https/g' bsCache.txt
The videos are showing up correctly on my page.
EDIT: Had to modify the code a bit.
Posted: Thu Oct 05, 2017 1:59 pm
by Fraggboy
So, my script modifies the time/date stamp check in
bloomskyTimelapseBlock.php.
if(file_exists("cache/bsCache.txt")){
if (time()-filemtime("cache/bsCache.txt") > 60 * 60) {
unlink("cache/bsCache.txt");
I am at a loss in how to get this fixed..
EDIT: I have modified my cronjob to every 60 minutes which is working good now.
Posted: Thu Oct 05, 2017 4:00 pm
by Johnny
Hi Christopher, just to let you know that your Bloomsky video is visible right now, I'm guessing you've gone back to HTTP mode. I think this is going to be one of those questions for Jachym to answer.
- Orbie and Stormie Bloomsky.JPG (29.19 KiB) Viewed 24567 times
Posted: Thu Oct 05, 2017 5:05 pm
by Fraggboy
Johnny,
I modified the cron job to run every hour since I believe the script checks for modification every 60 minutes.
I need Jachym's assistance.
Posted: Thu Oct 05, 2017 7:31 pm
If you just echo the raw output of the API do you see everything ok?
Posted: Thu Oct 05, 2017 8:42 pm
by Fraggboy
The API data is correct. It's just that all of the requests to amazon are http. When I modify it to https it works great.
As of now, my cronjob is working much better since I have it run every 60 minutes.
