CurrentCH & CurrentFR
Lespius
Station model: Davis VP2
Post by Lespius » Mon Oct 09, 2017 7:40 pm
Hello Jachym,
I have just installed (automaticly, works incredebly fine) the currentFR block. The icons are missing. Any idea to solve it?
I also have installed the swiss curent conditions. Is there a way to modify the wording of the names of the stations, ie add altitude ? Do we have access to the list, so I could do it myself, or is it datas directly received from MeteoSuisse?
Thanks for your feedback !
Alain
Re: CurrentCH & CurrentFR
Post by Jachym » Mon Oct 09, 2017 10:14 pm
did you apply the bug fix package I released today?
iatros
Post by iatros » Tue Oct 10, 2017 3:36 pm
Salut Alain
The list of all stations is here:
../hompage/blocks/correntCH/cache/currentCHCache.txt
There you can change the names of the stations (cf screenshot, I just added the Canton's letters for the first three).
I'm afraid you have to do the work for each of the data rows (Temp, Hum, Wind etc) - and never empty the cache!
Quite a bit of work....
Language Admin für Deutsch
Post by Jachym » Tue Oct 10, 2017 3:38 pm
The cache file is created automatically and refreshed every hour, if you make any changes it will be overwritten. And if you disable this, your conditions will not be updated too. Im afraid this cannot be changed because the names are loaded together with the data.
Lespius
Post by Lespius » Tue Oct 10, 2017 6:34 pm
Thanks Iatros. Unfortunately I am not surprised with the answer of Jachym...
Jachym, regarding the currentFR, the update doesn't change anythin I am afraid... The icons must be missing somewhere, I guess.
Lespius
Post by Lespius » Tue Oct 10, 2017 7:02 pm
OK, solved. The icons folder was missing. It is strange... First I have downloaded the block via the automatic way: icons missing.
Then I have downloaded via the old way: the folder is here....
Post by Jachym » Tue Oct 10, 2017 7:03 pm
Did you apply the bug fix package?
Lespius
Post by Lespius » Tue Oct 10, 2017 7:42 pm
Yes I did, but tonight after the first "automatic" download.
