Steel Series Gauges automatic scaling
Posted: Tue Oct 10, 2017 6:36 am
When a steel series gauge value exceeds the maximum setting of a particular gauge the maximum value (scale) will increase automatically.
This feature is handy for the rain and rain rate gauges where the daily maximum can be set to e.g. 10 mm or 2 inches. No need to set the gauge maximum value to the maximum recorded day value ever. When the daily rain exceeds 10 mm the maximum is adjusted to 20 mm and so on.
The same principle could be used for wind and gust speeds or other gauges.
Note: the steel series block (ssGauges) use the settings of the steel series plugin (Steel Series).
