Block for hay harvesting...
Posted: Tue Oct 10, 2017 7:07 am
by staccermaccer
I have some friends who have horses and they were asking me if there is a formula to calculate the ideal time for harvesting hay, this means, is it gonna stay dry and warm enough to harvest the hay dry so it does'nt rot.
I was asking myself if there was a possibility to make a little block or plugin of this.?
Greetings from Marc, Antwerp
Re: Block for hay harvesting...
Posted: Tue Oct 10, 2017 8:56 am
yes it would, but you need to provide some forumla to use. I can do the programming, but I dont know about any formulas to calculate this.
Posted: Tue Oct 10, 2017 10:19 am
by staccermaccer
Hi, Jachym
I have done a short search and it has much to do with dry and warm temperatures and no or litlle rain forecasted.
i am searching for a formula, though! I let you know if i find a scientifically right formula...And i think i've found a good base to start:
http://www2.ca.uky.edu/agcomm/pubs/agr/agr45/agr45.htm
extended dry periods with ample sunshine, light winds and low humidity. This is the ideal opportunity to cut hay.
Posted: Tue Oct 10, 2017 10:35 am
Yes, let me know if you find anything where all parameters necessary can be calculated from the data we have available in the database
