Tip: Adding Sticker to Forum Signature with Hyperlink
Posted: Thu Oct 12, 2017 12:21 pm
by MonyMony
Hi All,
Wanted to pass on a small tip. For those of you that have added your template Sticker to your forum signature, it is possible to turn the graphic into a hyperlink. You can see this in action if you click on my sticker it will link you to my page. What you need to do is format the signature like this:
[url=http://www.cecilweather.com][img]http://www.cecilweather.com/weather/cecil/plugins/stickers/stickerInteractive.php?text=Cecil%20County%20Weather%20-%20Elkton,%20Maryland,%20USA&image=01&border=2&type=interactive&dualUnits=1[/img][/url]
The key is to add the [url=http://{your site}] before the [img] and at the end of the signature string to add [/url].
Hope this is helpful to someone :lol:
Jay
Re: Tip: Adding Sticker to Forum Signature with Hyperlink
Posted: Thu Oct 12, 2017 12:33 pm
by Johnny
Brilliant - it works, thanks for this suggestion.
Posted: Thu Oct 12, 2017 1:03 pm
by Luc
Perfect! Thanks a lot for the tip!
Posted: Fri Oct 13, 2017 6:15 pm
by iatros
Nice, thank you!
Posted: Fri Oct 13, 2017 6:39 pm
In case you want to try more tags, look up BBCode, this is what the forum uses ;)
Posted: Fri Oct 13, 2017 8:24 pm
by meteocaldas
Jachym wrote: Fri Oct 13, 2017 6:39 pm In case you want to try more tags, look up BBCode, this is what the forum uses ;)
Thank you soooo much Jachym.
Now it is much easier for me to understand how to work with the tags :-)
I was already using the sticker hyperlink since the early days of the forum (thanks Kocher for teaching me!), but I also have to thank MonyMony for publishing this very usefull tip in the forum. Thanks.
Posted: Sat Oct 14, 2017 12:30 pm
by cw3beck
Thanks for the tip, Jay! I've been trying to figure this out for the last couple of weeks !
John B
Posted: Sun Oct 15, 2017 5:48 pm
by Weerstation Afferden
Thank you, it works fine.
Is it possible to translate the text in another language?
Posted: Mon Oct 16, 2017 1:44 am
by meteocaldas
Weerstation Afferden wrote: Sun Oct 15, 2017 5:48 pm Is it possible to translate the text in another language?
Jachym is the right person to answer that question, but I tried to do it and could not find any other solution than replacing all the ocurrences of the word "today" by the portuguese word "hoje" in stickerInteractive.php, like in this code example:
Line 579: textCenter($png_image,($width/6 * 2)+$widthShift, $recordsTopHeight1, ("Hoje"), 3, 8, $mainColor, 0);
Posted: Mon Oct 16, 2017 7:24 am
yes, correct, in the interactiveSticker.php you can replace the abbreviations with your own text
Posted: Mon Oct 16, 2017 9:43 am
Thank you meteocaldas, it works fine...
Posted: Mon Oct 16, 2017 8:59 pm
by MonyMony
I am glad to see that my tip has been so helpful! :D
Posted: Mon Nov 06, 2017 7:48 pm
by martymoose
works here as well great work
thanks
