Adding Soil Temp sensor
Posted: Sat Nov 04, 2017 12:42 am
I am considering adding a soil temp sensor to my Davis wireless Vantage Pro 2 station.
I see in the station setup section of WD that I can add and specify how WD adds the soil temp (temp1, temp3, temp5) to its database.
I am using WD API to send data to my Meteotemplate website.
Questions:
Assuming Weather Display will insert this additional field into its data packet, how will it be handled in MT?
Assuming that WD does its job correctly, I'm guessing that I would just have to map that particular data point to the correct field in Meteotemplate MySQL database.
I have looked at the 'soil' block and it displays more information than I will provide it. I am not adding leaf moisture and will only have 1 temp sensor, although I could easily add another one or two. I don't see a SS Gauge for soil temp. I really like the SS Gauges, they're sharp looking. Are there any other options for displaying an extra temp sensor?
Advice?
Anyone see a problem with this? Is anyone currently doing this.
thanks for your wisdom.
Questions:
Advice?
