Current conditions - not showing trends
Posted: Thu Nov 23, 2017 9:35 pm
by martin.b
I am trying to find out, why my current conditions block doesn't display trends (small arrows below numbers). Did somebody observe the same issue?
Re: Current conditions - not showing trends
Posted: Thu Nov 23, 2017 11:53 pm
1. check you have "trends" enabled in Current block settings
2. if still no luck, please post a link
Posted: Fri Nov 24, 2017 6:47 am
by martin.b
Yes, trends are enabled, the link is: www.modrehory.sk/tpl/ Thanks!
Posted: Fri Nov 24, 2017 10:42 am
The block seems to have errors, but it also seems to be modified, did you modify the code yourself?
Posted: Fri Nov 24, 2017 10:43 am
by martin.b
Yes, but the trends were not visualized also before the modification :(
Posted: Fri Nov 24, 2017 10:46 am
OK, well it is hard to actually tell because Im not sure about all the changes you made, all I see now is a Javascript error "somewhere" in that block
Posted: Fri Nov 24, 2017 10:57 am
by martin.b
OK, I just added another temp sensor...
BUT: now I reinstalled the original block - and trends are missing too :(
Posted: Fri Nov 24, 2017 11:07 am
OK now I see the JS error - it is because you have no pressure, this is causing problems
Posted: Fri Nov 24, 2017 11:48 am
by martin.b
OK, I see. Thank you for advice.
Posted: Fri Nov 24, 2017 11:57 am
No pressure means the block works in a limited mode and this causes issues with the trends
