yr.no/place/United_States/Maryland/Rock_Hall~4367081/
this is the url.....I only want this one location.....can anyone help me with the syntax'
to put in meteogram.......
everything I've tried as failed
thanks
Steve
meteogram not loading
Re: meteogram not loading
Clear the cache folder and try
Rock Hall,United_States/Maryland/Rock_Hall~4367081
evetsmd
- Station model: Davis Pro2, Model 6153
Thanks for the suggestion but still not working
I get this message " Failed loading data, please try again later"
Try deleting the cache folder. If that does not help then Im afraid it is a communication problem between your server and yr.no, it would not be the first time I see this
evetsmd
Very strange.....woke up this morning turned on the computer and it is working...I think I read someone else had the same problem with the same solution as an end result.....
Thanks for ur help!
Steve
Thanks for ur help!
Steve
Great, either it was cached or temporary communication problem
