wetbulp
Posted: Sat Dec 09, 2017 11:42 am
by Torjan
Hi!
I have the wrong value in wetbulb in current condition block.
Temperature
1.9°C
Apparent temperature
-5.2°C
Dew point
0.4°C
Heat index
--°C
Humidex
-0.2
Windchill
-3.7°C
Wet-bulb
7.5°C
http://regnskvett.com/meteotemplate/indexDesktop.php
Re: wetbulp
Posted: Sat Dec 09, 2017 8:43 pm
by MarTM
same problem...
Temperature -2.4°C
Apparent temperature -6.0°C
Dew point -13.1°C
Heat index --°C
Humidex -6.7
Windchill -- °C
Wet-bulb 3.5°C
Re: wetbulp
Posted: Sun Dec 10, 2017 1:28 pm
This one is problematic, it was not easy to find the right equation, this is the one used see if you can find any alternative one or the mistake in this one:
function getWB($WB_T,$WB_H){
global $displayTempUnits;
$e = $WB_H / 100 * 6.105 * exp(17.27 * $WB_T / (237.7 + $WB_T));
$WB = 0.567 * $WB_T + 0.393 * $e + 3.94;
$WB = convertor($WB,"C",$displayTempUnits);
return number_format($WB,1,".","");
Re: wetbulp
Posted: Mon Dec 11, 2017 7:04 pm
by wx_jon
Well, clearly something is indeed wrong with that formulation since wet-bulb temperature must lie between dew point and air temperature. The formula you have doesn't guarantee that. How about using this glorious mess?
Re: wet-bulb
Posted: Sat Apr 13, 2019 9:15 pm
by WSKO_Karlchen
Wetbulb is still a mess... the formula must be wrong :( it’s way to high!
If I use a calculator it should be -0.2°C not +6.3°C like mentioned by the template...
www.wetter-koblenz.com
Re: wetbulp
Posted: Tue Jun 01, 2021 4:57 pm
by mitmas
Try:
$e = atan($WB_T + $WB_H) - atan($WB_H - 1.676331) + 0.00391838 * ($WB_H)**(3/2) * atan(0.023101 * $WB_H) - 4.686035;
$WB = $WB_T * atan(0.151977 * ($WB_H + 8.313659)**(1/2)) + $e;
